12-28-2009 | #21 |
Re: Thickness of water pump gasket??
I actually have a spare gasket from a kit I ordered a couple of years ago when I did my head gasket R/R. Thanks for the reminder though!!
1991 Chevrolet Corvette ZR-1 |
12-29-2009 | #22 |
I hit the same thing a year ago when I replaced my water pump. It ended up being the actual impeller was not on the shaft properly. It was a royal PITA. I had to remove and return and get another and install.
01-03-2010 | #23 | |
Rich
01-03-2010 | #24 |
Well, I decided to go the "reman" route one more time and bought one from H2OPumpMan on eBay. The impeller looks perfect and it came with the correct gasket with the bead on it. I installed it today and am ecstatic to say, it's perfect! The beast is back!
