12-14-2009 | #21 |
Re: What ZR-1 Item is on you Christmas list.
Hans,
Yes the studs, at stock lengths and I believe the next length up, can be done with the hubs on the car. If you look behind the hub, as you rotate it, you will see an area on the face of the knuckle that has enough room for the stud to be driven out and the new one to be started in the hole. If I remember right, the space is on the forward part of the knuckle. or on your left as you face the hub. Tom
12-14-2009 | #22 |
On the install, you need to grind down part of the head of the stud....not the part that actually creates the interference fit. Just the top portion of the head...common practice with doing this.
12-14-2009 | #23 |
Depending on the length the longer stud may slip into the hub without needing any work.I ground down a spot before I replaced the stock studs.G.M. makes longer studs,the part# is 22551491.[IMG][/IMG]
12-14-2009 | #24 |
Those are the studs I have. I'll be grinding down the head a bit. The stock studs came out with little effort.
12-14-2009 | #25 | |
12-14-2009 | #26 |
I'm into simple pleasures. Just a '95 ZR-1 key ring. Anyone has one for sale? Does not have to be perfect.
Peter '95 #442 http://www.zr1netregistry.com/forum/...ad.php?t=10575 Last edited by petefias; 12-14-2009 at 05:51 PM. |
12-14-2009 | #27 |
Just a coolant hose set Mr. Santa - black, not Samco.
12-15-2009 | #28 |
Couple of things on mine:
Hurst shifter Engraved center caps from Carter...haven't forgotten about you. LT5 emblem from Carter...if Jeff is willing to powder coat it. Already got new emblems from lgaff and they look great!
1969 Camaro RS/SS Convertible, 427 4 speed 1996 LT4 convertible red/black/black 1996 LT4 convertible yellow/black/black 1995 ZR-1 white on red |
12-15-2009 | #29 |
Coil overs
12-15-2009 | #30 |
I want a mig welder nothing fancy already have the one I want picked out.
Lincoln electric 140 HD anyone needs my address for the shipping let me know |
