12-13-2009 | #21 |
Re: Help! Engine Noise
Where would we be without all the good folks & the forum to put us in touch?
12-13-2009 | #22 |
Rich,
Let me know when you are going to do the job. I will try to come down and lend a hand. If the pump doesn't come with a gasket, get it from Jerry! Jim
12-13-2009 | #23 | |
Thanks to everyone who had input on this thread, appreciate all your input, this is what makes this site the best
12-13-2009 | #24 |
Absolutely Jerry. The Registry in action.
[I][FONT=Comic Sans MS]John Boyd[/FONT][/I] [I][FONT=Comic Sans MS][SIZE=1]Ideho[/SIZE][/FONT][/I] [FONT=Comic Sans MS][SIZE=1][I]2015 ZL1 [/I][I]Camaro #1121 BLACK/BLACK 6 SPD (540 RWHP)[/I][/SIZE][/FONT] [I][FONT=Comic Sans MS][SIZE=1]1991 ZR-1 #458 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK 72[/COLOR]k miles ([B][COLOR=red]SOLD[/COLOR][/B]) 1991 ZR-1 #473 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK [/COLOR]37k miles ([B][COLOR=red]SOLD[/COLOR][/B])[/SIZE][/FONT][/I] |
12-13-2009 | #25 |
While you had the belt off you did reach down and gave the WP pulley a spin right?It would be a kick in a balls to do all this work only to find out it was something else.
12-14-2009 | #26 | |
Rich
12-14-2009 | #27 |
Rich, Since the noise went away with the serp belt off, the faulty component still could be any of the things that the belt touches:
Water pump Alternator AC Compressor Power Steering Idler Pulley Crank pulley/torsional damper You may want to keep checking to figure out which one it is before you replace the water pump. Jim |
12-14-2009 | #28 | |
Rich Im thinking Jeff feels you should still hear some of the noise when you give her a hand crank. It may be lower in volume and a different pitch but you should still hear it. If its a spun bearing you might even feel resistance. Which is futile. But as posted above Jim is right with the S belt off everthing is in play. Did you see any rise in temp with this new noise or did you not notice?
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 12-14-2009 at 09:22 AM. |
12-14-2009 | #29 | |
Rich
12-14-2009 | #30 | |
