#21 |
![]() Join Date: Aug 2005
#22 | |
![]() Join Date: Aug 2006
What's your Compression Height going to be? Smallest I've ever run was 1.0" |
#23 |
![]() Join Date: Jan 2004
Looks like you're doing a first class build
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
#24 |
![]() Join Date: Dec 2004
Please forgive my lack of knowledge demonstrated by the questions that I am about to ask!
![]() The reshaping of the combustion chamber like what Todd has, is that a good idea to do to a stock displacement motor? I have read that our bore spacing is not optimal ( I don't understand why, but I accept it as a fact ) and that is one thing that gets solved with bigger liners? Sorry, another Q, if not a stock displacement motor, then what would be a good displacement to go to? I read the posts about how expensive it is to rebuild an LT5 to stock displacement/configuration. It obviously seems that if you need to rebuild your LT5 it is more cost effective to go up in cubes. Is it because the bigger liners and pistons and rods and the machining ( off-set grinding ) of the crank ( what is that btw? ) almost equal the amount of money spent trying to get "stock" parts? I'm sure that it's the stock cost vs the new power from the expensive bigger stuff, the balance tips to the bigger stuff because of the power added, right? ![]() ![]() grasshopper
1990 ZR-1, Black/grey, #2233, stock. ZR-1 Net Reg Founding Member #316 & NCM member Last edited by tomtom72; 12-05-2009 at 09:22 AM. Reason: I put the wrong name, sorry. |
#25 | |
![]() I think with all the "take out " parts people have, to rebuild a stock 350 would not be that much. I have seen and have myself liners,pistons,rods,rings,pins.. Whole drop in's for under $1000. Yes these are used, but if the rings have good tension and good gap.. under 10k miles whats not to reuse. So, you have all 8 holes for under 1K. My 402's JE pistons were $2200 or $2400 just piston's and rings. Then liners,rods,machine "bore & hone". |
#26 |
Finally got the injector housings back. A little welding was needed
![]() Interesting, the area is not huge on these things. We're less than 36mm at the runner entry. Todd |
#27 |
Very nice, Todd =D>.
#28 |
You maybe farther along then me, but I know I have something you don't
![]() ![]() Housings look good Todd |
#29 | |
Looks good Todd, glad your happy, you had a 'Good' guy doing them. |
#30 |
![]() Join Date: Nov 2008
