Old 12-28-2009   #21
Default Re: Differential Case
Originally Posted by Scrrem View Post
Wow Craig....looks awsome!!! Can't wait to see the case. In hind sight, I wish I had hit mine with some paint too, but it came out OK.
Rich
Thanks Rich. I'm sure you did the right thing by keeping it original looking and yours came out nice from your pics. We'll see how this POR-15 holds up in the long run.
Old 01-07-2010   #22
Scrrem
Scrrem's Avatar
I am assuming that your 90' case (is it a 90'?) does not have an oil drain plug. If not, did you install an oil drain plug since you have it all apart?
I am actually thinking of installing an oil drain plug (drill and tap) without taking it all apart
My thinking is......any debris in the differential settled in the bottom of case is very hard to suck out by conventional means and any aluminum shavings (very little if I do it correctly) will all drain out including the other debris when I get the new threaded drain hole installed
And...if I screw it up....that will be a great reason to go to 4.10s
I used that tap kit when I did mine back in November. I was going to pull the axle to install 4.10's anyway, but I wanted to see if any shaving were left in the case. I taped the case and let the oil drain, then pulled the axle out and popped the cover. Couldn't find any shaving inside, so I would feel pretty confident using that kit.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 01-07-2010   #23
Rich
Thanks for that information.....what size plug did you install?
Did you tap into the differential case just South of the lower center bolt on the flange?
That would be just below the ring gear I think? (Vet facing west)
Old 01-07-2010   #24
Scrrem
Scrrem's Avatar
I am not sure of the tape size, bought the kit below from Corvette Central:
http://www.parts123.com/parts123/yb....Z5Z5Z50000050F
The kit provides a template that puts the hole just left of the center bolt in the valley of the differential. See pic:
Ron Davis Radiator
Old 03-15-2016   #25
I placed the Differential Drain Plug just on the Drivers Side of what I call the Molding Seam in the Center of the Flange Thickness of the Differential.
See Item #4 LT5 Added Systems
Post 147 - LT5 Added Systems
Differential Drain Plug Kit
Old 03-15-2016   #26
Racinfan83
I'm doing this drain plug. I got a new 1/8 x 27 npt tap off eBay for like $5. Had the 11/32 drill bit already. Got 2 1/8 plugs for $5 on eBay. So whole deal is waaay less then that kit....
[LEFT][SIGPIC][/SIGPIC][/LEFT]
[CENTER][COLOR=Indigo][SIZE=4][I][B] **Now Sold** 1990 ZR-1 #2093, Black on Black..[/B][/I][/SIZE][/COLOR][/CENTER]
Old 03-15-2016   #27
RussMcB
One nice part of the kit is the tap has a stop welded to it. Not a necessity, but helpful. It also comes with a template to help determine the hole placement.
I plan to buy a bunch of extra 1/8-27 plugs then sell my kit (with spare plugs) to someone, who can use it then sell to the next person, etc.
