#21 |
#22 | |
![]() Join Date: Nov 2006
#23 |
![]() Join Date: Aug 2006
#24 |
I recently switched my 92' Z to Mobil 1 high mileage formula, not because of high mileage (it has 41,000 miles) but I've always used M1 10w30 since new, M1 HM has plenty of zinc and also seal conditioners which I feel is important to our aging engines. I also used the Bosch oil filter. I get my M1 at Wally world so for a complete change oil is less than $50.00
![]() Last edited by zrmynatt; 11-18-2009 at 04:27 PM. |
#25 |
I am in Spain and the Mobil 1 that is available here is either 0w40 or 5w50. Anybody got any ideas which (if either) would be best for the LT5?
#26 |
![]() Join Date: Dec 2007
Richard, my friend Ramon (our local LT5 specialist) uses both of them. Now I'm with 5W50 and no issues at all so I feel both choices are good. I wish some day I find a good explanation for the different oil grades between the US and Europe.
#27 |
![]() Join Date: Jan 2007
It's my understanding that the only Mobil 1 that contains zinc is 15W50, which is the lube for our cams.
#28 | |
![]() Join Date: Aug 2007
Nice to hear from a ZR-1 owner in Spain. About the Mobil 1 thing, I use Mobil 1 5W50 for my Corvette. The Mobil 1 grades you will find in Spain will not be the same that are available in the US (which are ALL). I suppose it's a weather temperatures or commercial issue. I have been using for more than 2 years, from when I bought my ZR-1 in the US, the Mobil 1 5W50 without any problems. I also use it in the ZF manual transmission, and works OK. I have done about 40.000 Km in the last 2 years and without trouble. You can also find Mobil 1 0W40 in Spain, but its price is more expensive than the 5W50, so I switched to 5W50. And theoricaly it has a wider temperature usage. Ramon. |
