Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > Detailing, Cleaning, and Waxing
Old 11-23-2009   #21
carter200
carter200's Avatar
Default Re: Engine Cleaning
Originally Posted by Kevin View Post
next time leave the wheels on and sit on them
That's what I do
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 11-24-2009   #22
QB93Z
QB93Z's Avatar
Sounds like a plan!
Old 11-25-2009   #23
Hammer
Hammer's Avatar
Talking Re: Engine Cleaning
Well I thoguht I'd let you know what I used for my engine. Your drain hole must be clean to do this though. I use GUNK ENGINE BRITE...soak the motor and compartment down with it . Sits a few minutes and then let 'er have it with the water enough to wash the GUNK off. I have done this with both the ZR-1's now. Of course I don't do it every weekend, just initially to get the grime off, and #473, this one was real dirty. Then I have had success with Adams Buttery wax and In-n-Out spray (No Longer Available) all over the engine compartment. I keep my engines pretty clean on a weekly basis.
What do you think?
Old 11-25-2009   #24
ScottZ95ZR1
ScottZ95ZR1's Avatar
Damn. That motor looks clean as a whistle, John.
ScottZ95ZR1 is online now   Reply With Quote
Old 11-25-2009   #25
Its Filty John. Thats the worst brake fluid Ive ever seen!!!
Wow damn claen!!
Old 11-25-2009   #26
QB93Z
QB93Z's Avatar
Very nice John. Mine will never look that good. Every time I start to work on cleaning, I get an over-powering urge to go for a drive.
Old 11-25-2009   #27
Wow John,
Great job!!! I miss that In and Out spray too!
Old 11-25-2009   #28
4DSZR1
4DSZR1's Avatar
Friggin PERFECT John :-)
4DSZR1 is offline   Reply With Quote
Old 12-02-2009   #29
ZR1ROB
mmm shiny good!
If you have to pull the plenum, you might as well enlarge the drain hole in the back of the starter valley. Thats the problem child. 3/8" drill is what I remember opening it out to. Not a problem since. Now I'm going out to get some gunk engine bright. mmm shiny
ZR1ROB is offline   Reply With Quote
Old 12-05-2009   #30
Hammer
Hammer's Avatar
Originally Posted by ZR1ROB View Post
mmm shiny good!
Let me know what you think. I washed one car at the car wash. That one I hadn't cleaned the plenum hole out. Didn't have any problems.
The other one, Ive cleaned twice that way. The hole was cleaned and you can actually hear the water draining, a sucking sound kinda was heard.
If you can, take some before and after pics.
