12-01-2014 | #21 | |
Re: Brighter Aftermarket Headlamps
I'm looking at a MY90 wiring diagram right now and the fog lights are not grounded through the high-beams, but they do share the same ground connection. Left is G115 and right is G116. From an electrical standpoint, I don't think "grounded though" and sharing the same ground point are the same. But then...maybe I'm missing something.
12-01-2014 | #22 |
isn't this the same as the 90? I scanned it a while ago and it might be 89.. I know the 89 and 90 are very close for the forward electrical harness:
Here is the MY91 (forward harness changed): I will check my 90 FSM tonight if time allows
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
12-01-2014 | #23 |
That scan is from the MY89 FSM.
12-02-2014 | #24 |
yep just checked.. 90 is the same at 91
12-02-2014 | #25 |
So it appears the LED headlight upgrade would be a good upgrade and use less power.
With LED Headlights your foglights will no longer work properly. Is that correct? Has anyone tried using E Code lenses and HID conversion kits?
12-02-2014 | #26 | |
I have E-Codes and I forget which wattage bulb, they are better than stock though. I don't have HID but happy with the light output of the ones I have.. I think they are 55 watt and a bit better than the Silverstars I had in my last vette..
12-02-2014 | #27 | |||
1) Lots of glare to oncoming drivers. 2) Not very good light pattern because E-code reflectors are designed to work with H4 incandescent bulbs not HID bulbs. 3) likely illegal in some states. What they will achieve is making sure oncoming drivers know your car is equipped with HIDs. The only C4 HID conversion which anecdotal accounts indicate may actually work well is the product sold by CorvetteHID.com
12-02-2014 | #28 |
Drive on darker streets?
People always want me to dim my low beams!! |
12-02-2014 | #29 |
There we have it. Spoken by an anecdotal daily driver who has been running this mod since 2012
12-06-2014 | #30 | |
If you reaim the lights you may find that in high-beam the lights actually work better because they put more light on the road and less into the sky. Good luck!
