03-30-2008 | #21 | |
Re: Off idle stumble...................
From what I've been able to see there isn't a AE PW table based on Delta TPS%. I do see a constant for Delta TPS% to allow MAP AE but again no table. The stock 92 bin has a flat AE PW for MAP. Which cal year started using the "sloping" AE? I'd like to look at that. With modded motors it may make sense to add a bit of decay and possibly increase the PW a bit at the lower Delta MAP. Probably want a bit more fuel going there at smaller Delta MAP since tthe secondaries are not likely to kick in. |
03-30-2008 | #22 | |
You're using TunerCat, right? There are probably 500 items not defined in TC's definition files. D-TPS Acceleration Enrichment is among them, constants AND tables. And, as I said, don't think the AE things are all labeled right in TC anyway. I will say that the initial D-TPS AE term is not a traditional table like the MAP AE is, but it is in there nonetheless. The BMCB is one that I know has the sloped MAP AE values. This is without a doubt the most frustrating part of any calibration to get right. It's a delicate combination of many factors to get it just right. And lots of trial and error, and trial again. Todd |
03-30-2008 | #23 |
Todd,
I use TunerPro RT. Tunercat has a 99 item limitation. Any chance you'd send or post the section of the code with the D-TPS table for AE? |
03-31-2008 | #24 |
Have you tried Jeff? Why not support someone who supports the forum,
bet he could take care of you.
1990 ZR1, 142,000 miles-Black on black 4.09's Haibeck chip, 3"exh, K&N, meth inj. |
