#21 |
![]() Join Date: Apr 2007
As Gunny mentioned, I have posted a lot on my exhaust cut outs. There are a couple of pictures in my albums section, and here is a link to a thread about my switch hidden under the carpet.
http://www.zr1.net/forum/showthread....xhaust+cutouts There is also one picture of the cutouts themselves. I enjoy mine. Quiet and legal when anyone is listening and straight pipes when I want it. I usually drive around with them about one third open for a little rumble and close them when I come home so my wife doesn't complain about the sound. --Bob
#22 |
![]() Join Date: Jan 2015
You don't have to lift the engine to install headers, BUT, it is very easy to do, and if you slip in a shim on the driver's side it gives you a little more clearance between the header tube and steering shaft. I had to dimple my OBX header tube to get desired clearance.
The Stage 8 bolts are kind of nice even if you don't use their locking feature. Their combo external/internal hex heads give you the option of using an allen wrench (especially nice with a ball head wrench). Some O2 sensors have a longer harness, so no need for an extension. I think you can find the brand/model by searching here.
Russ McBride, [COLOR="Red"]Car Sold 8/2020[/COLOR] #1635, Marietta, GA USA, 1991 ZR-1, #766 (bought 1/1/2015) MS3-Pro, OBX, SW X-Pipe, Borla, Hurst, SLP, Goodyear F1 GS-D3, Kenwood. HOTB 2016Q3 [IMG]http://zr1.net/forum/picture.php?albumid=316&pictureid=2873[/IMG] [IMG]http://zr1.net/forum/picture.php?albumid=336&pictureid=2985[/IMG] |
#23 | ||
#24 | |
With Stainless Works Headers none of the issues you mention exist. The O2 sensor pigtail extension comes with the Stainless Works Headers and the Stage 8 Locking Bolts fit perfectly using either a socket or allen head wrench ![]() |
#25 | |
![]() One setup I loved on my 93 LT1 car was longtube headers, no cats to factory cat back. It was loud at wot, and almost stock like in all other conditions and had 0 drone or resonance at any speed. That would be my suggestion (although with high flow cats) based on what you are looking to achieve. regarding my car yes I do feel its loud at wot but to say its loud all the time would be an overstatement. Don't forget many of my videos on my channel are using a microphone on the back of the car to help capture the LT5s awesome engine sound. If you listen at 1:40 and beyond in the video you linked of my car.. listen to how quiet it actually is. it does NOT rumble and make noise all the time. far from it. I like to think of it as a Jekyl/hyde system where it can be quite tamed.. especially at cruise and relaxed driving and super angry on command ![]() here is a video of me warming the tires for fun.. from my iPhone from 15 feet away. Hardly obnoxious in my opinion... You can actually hear the engine over the exhaust through most of it. https://www.youtube.com/watch?v=keqajaZSp7g Going with no cats may gain 1 hp but gain lots of stink and smell and will make the exhaust sound more 'raw'. Me I prefer a refined and toned sound even if it cost me some hp (admittedly a straight through system like corsa wasn't all that appealing to me but it was the silence at cruise that made me go this route along with the construction material) I have lots of videos of just idleing and walking around the car Ill post one up for you so you can hear how it sounds from all sides. Still , my recommendation is Longtubes, high flow cats, factory cat back. It will sound much better than stock, well muffled, no drone or resonance, loud at WOT, and appear factory stock from the outside. ![]() |
#26 |
![]() Join Date: Nov 2013
i actually love you exhaust note so much i went and bought a corsa and had it installed with long tube headers and no cats. i have not heard it yet since my car is still at south georgia corvette but i will be picking it up in a week. corsa is the best exhaust i have heard. i removed my flowmaster force system. i found the resonator was very restrictive along with the three chamber flowmaster mufflers.
it was the sound of your car that made me go out and buy the corsa. i cant wait to hear it and with additional engine porting and a fidanza flywheel i should see more power along with more sound. ed ramos #3028
EDRAM454 1990 #3028..siamese ported plen/hous/SGC/fidanza/DRM LTHeaders/DRM roll cage/camber rod/drilled slot rotors hawk track pads/grand sport calipers/full corsa exhaust/Hurst/NO cats/custom SGC chip/cbeamplate/315's on all 4/intake water plugged/smog removed..RC injectors/LED lights..SHOULD NOT HAVE PUT ALL THE MONEY IN IT.. SOLD. |
#27 | ||
![]() But it is too loud for where I live. I even linked one of your videos on the 1st page of this thread. They are pretty strict here regarding exhaust noise. Thanks for all your reviews guys! |
#28 | |
To the OP, I think Warp Ten has the best Set-up of all and his Z does not look so crazily pimped out like others here. My $0.01 ![]() |
#29 | |
![]() Join Date: Feb 2011
Even if you run stock mufflers with no cats and headers (the quietest combination) you will still find it very loud. Headers just open these engines up and the decibels increase a lot. I did run the LS7 catalysts on the end of Watson headers with the StainlessWorks mufflers using a flap on one of the outlets. This helps IF you keep the flap closed. It is loud as hell if you open it up. |
#30 |
Warp Ten has the best C4 Exhaust Set-Up I have ever seen.
