08-15-2016 | #21 |
Re: Stuck!! No crank ! LF some input and help !
As long as you are not standing in front of or behind the car
08-15-2016 | #22 |
Haha my first thoughts
If I may ask .. Assuming the car cranks jumping the purple wire , what would be the reason for not cranking with the key ? Vats? If it doesn't crank then I guess it's time to pull the plenum. Again forgive me for not searching (and I will shortly) but should I rebuild the starter or are there reliable or preferred replacements ? I am regretting not cleaning the contacts etc when I had the plenum off last year. I was a little intimidated by the plenum and removing the secondaries at the time and decided not to dive in further and just pull the starter. On the bright side I have new wires waiting to be put on .. Can't be certain on the age of the current ones although the car runs great. |
08-15-2016 | #23 |
The starter Solenoid is getting current directly from battery when jumping purple wire..... no current loss through switches and connectors. The Solenoid jumps faster with more pressure on contacts.
Actually the total resistance in circuit is reduced by jumping and I = V/R Sent from my iPhone using ZR-1 Net Registry
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 08-15-2016 at 01:42 PM. |
08-15-2016 | #24 | |
08-15-2016 | #25 |
No. You can turn the ignition key to the On position, (set emergency brake and put the car in neutral), then lift the hood and touch the purple wire jumper to the battery's positive terminal. The engine should start and run.
08-15-2016 | #26 | |
** update!** I added a quality copper power wire (8gaw I think) to the purple wire in the harness. Starter engages perfect every time. Fired right up. I added some wired taped everything up , capped it and curled it within the cruise control bracket so it's out of sight. I will attach pics so people can see if it helps So now , clutch switch is bypassed. Starter cranks with straight power. Any ideas what it could be ? Vats ? I assumed vats wouldn't let it crank or cuts ignition or fuel ? |
08-15-2016 | #27 |
Few pics .. Will add to the original post to help anyone if it might in the future who searches and comes across this thread. Thanks to all your guys help so far at least I am now able to fire the car up until I get it sorted out !
Harness under the ECM. Purple wire I added a 8awg quality wire I had laying as spare. Touching this to the battery positive terminal cranked the motor instantly. Added a rubber cap and taped it and the wire later for extra protection. Easily hidden out of sight. Now to figure out why the starter isn't getting power when I turn the key.. Hmm.. Last edited by 5ABI VT; 07-06-2017 at 04:05 AM. |
08-15-2016 | #28 |
You sound exactly like me 18 months ago. :-)
After doing the quick, temporary fix, I did the VATS bypass and relay mod and haven't had to use my hidden jumper wire since then. |
08-15-2016 | #29 | |
I'm still trying to understand what the relay mod does exactly. I believe it bypasses the vats and the clutch switch (optional) ? I was nearby the electronics store and checked my pellet and got 6$5 ohms. I grabbed a resistor and will bypass that part of the vats for now |
08-15-2016 | #30 |
The relay mod if you are talking the relay mod I described in a Link.......only requires current to close the main points of the relay after which the main points of the relay pass current from the battery directly to the Field coils of the Starter Solenoid. The magnetic field created within the Solenoid is then maximum with maximum force on the Solenoid points created. The Solenoid points then pass maximum current allowed from battery to Starter motor.
Reconditioning the starter Solenoid involves cleaning/replacing the Solenoid points......and cleaning the plunger itself. Sent from my iPhone using ZR-1 Net Registry
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 08-15-2016 at 08:11 PM. |
