Old 04-08-2011   #21
gbrtng
gbrtng's Avatar
Default Re: Part Number for ignition module connector
I usually bring out my assortment of small files for this problem ...
Old 04-09-2011   #22
VetteVet
VetteVet's Avatar
Originally Posted by VetteMed View Post
I can't seem to find this connector anywhere -- it's the driver's side front 3-wire connector on the ignition module. The internal connector shape is the same as the other front 3-wire connector, but the clip is different. I can only find this one:
http://www.amazon.com/ACDelco-PT472-...6410716&sr=8-5
Anyone know that website that lists the connectors by picture? I used to have it bookmarked...
I think that this is the one that you need:
http://www.rockauto.com/dbphp/x,cata...lco_PT782.html
http://www.rockauto.com/catalog/moreinfo.php?pk=82769
Old 04-09-2011   #23
Tyler Townsley
Info page with possible links/
http://www.rowand.net/Shop/Tech/Auto...Connectors.htm
Tyler
55 Polo White (Project)
61 Jewel Blue (Sold to buy above)
66 Nassau Blue
68 Torch Red
88 ZR1 Blue
90 ZR1 White
Old 04-09-2011   #24
VetteMed
Originally Posted by VetteVet View Post
CLose, but no cigar. That's listed as a part that might work, but if you read my prior post(s) in this thread, you can see that the connector body is clearly a different shape.
Old 04-09-2011   #25
VetteMed
Tyler
Thanks, Tyler - I'll check those links.
Old 04-09-2011   #26
VetteMed
I MAY have found something that will work - will update as soon as I receive the part.
Old 04-09-2011   #27
WVZR-1
Using a '94MY FSM the connector for C3 is a 12059612 (empty connector), using some GM SPO information the PT472 is considered a "service replacement" for that connector. "Service replacement" doesn't mean "exact match"! Wire gauges supplied maybe lighter/heavier but considered "suitable".
I don't use many "pig-tails" when I need specialty connectors I usually try to source the empty connector, use terminals, seals individually and assemble it OR using a release tool transfer the terminal from the original to the replacement.
NO CUT AND SPLICE!!
I keep a '94 FSM for the reference information to the connectors.
I buy from several sources that don't have the 12059612 but look here:
http://avilaelectronics.com/
I linked to the home page, click on the search tool and you'll see 13,000 +! I didn't try the phone number and I also likely won't. Someone can post back!
Here's the Delphi "tool" I use for most of my projects. Instead of linking you directly to the 12059612 here's a "start page" and you can enter the 12059612 in the search block. Here you'll find correct terminals for various wire gauges (note the metric values), seals, release tool information, 2d and 3d prints if available, material composition etc.
http://connectors.delphi.com/dcsgdmcs/homepage.aspx
Most FSM's beginning in MY'94/95 or later display "empty connector" information to facilitate harness repairs.
Do I use "pig tails"? Sure but not often.
I found some other 280 connectors that I believe would do but I don't have them in my hand so I didn't reference them!
FORGOT TO MENTION: Check the "line drawing" under prints etc!
Old 04-09-2011   #28
VetteMed
I have ordered a bare connector earlier this morning, I was previously looking for a pigtail since I didn't have the crimping tools, but I figured this is a good excuse to make the investment. I know that PT472 will fit into the ignition module receptacle. However, the clip design does not appear to be able to fit over the retaining nub on the ignition module. I could be mistaken, perhaps it's able to be "rigged" to fit in a way that it wasn't designed for.
Old 04-09-2011   #29
WVZR-1
What did you order?
I'd be interested if someone could check a '95MY FSM for connector information for the ICM. The '94MY seems to have errors. Transitioning from bare connectors to "pig-tails" and also some of the replacing part #'s for empty connectors don't seem to agree or be able to be confirmed.
Old 04-14-2011   #30
If one would like to make the investment for the tools to work on the connectors used on our cars what would those tools be called? Weather Pack tools?
TIA
