Old 02-08-2011   #281
Default Re: LT5 Assembly Project
I will get more info, he has pull out his notes on the project from 15 years ago.....and he will let me know what it will all entail.
Old 02-27-2011   #282
Started to siamese the intake: This is without smoothing it out with the large flap wheel
Will need a dremel tool to clean up some of the ridge in between
Old 02-27-2011   #283
Pete
Pete's Avatar
Nice.
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 03-05-2011   #284
The are the IHs that were machined to 36mm a few mm into the port, well I found out why they did not use them, the walls are thinner by about 1.5mm and so 36mm all the way through is not very easy....but the will do just fine siaimaesed.
Stil need clean up and take ridges down:
Old 03-06-2011   #285
Pete
Pete's Avatar
and so 36mm all the way through is not very easy....but they will do just fine siaimaesed.
Now then try getting a 36.5 mm ball go all the way thru or 37mm go halfway,my own IH/plenum are this way.
I do 36mm ball go all the way thru.
Like you said they start to get thin.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 03-06-2011   #286
Pete
Pete,
Does this mean that you must kill all of us now that we know this?
Old 03-06-2011   #287
Polo-1
time to get the welder out..... been down that road
Old 03-06-2011   #288
I used alumiweld from harbor freight, it actually worked.
Old 03-06-2011   #289
Pete
Pete's Avatar
Lee,does the alumiweld work?
Dom,no i won't have to kill everyone for this info just saying what i have done to my own intake, have not lost low end at least nothing that shows up on Dyno sheet or seat of the pants.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 03-06-2011   #290
The Alumiweld works if you can keep the parent metal at the required 730 degrees, which I had a hard time with. First one did not work, second one worked well, but I could have used more practice, first time I used it.
Aluminweld, bonds to the parent metal it is not integrated into to as with a weld. It however is very solid......key is how clean the parent metal is too, stainless brush and some acetone need to be used.....I probably could have taken more time in cleaning.
