07-11-2017 | #261 | |
Re: TB removal and then some!!!
Ok, put some time into the garage today, even with the heat....made more progress, any progress is good progress....starting to look like a LT5 once again. Things went pretty smooth today, just took my time and got it done... Some pics... started by getting the back of the engine hooked up...painted the 2 black screws later. thought I had replacements, but who knows... pulled out the elbow....and inserted the plug... needed to bend the pins out to fit, could have gone with slightly larger plug... coating the coolant pipe gasket with Perfect Seal... always trying new ways for gasket attachment....lol sometimes it works, sometimes it doesn't....
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 07-11-2017 at 08:19 PM. |
07-11-2017 | #262 |
LS on.....
have to do some minor touch up on the PCV pipe....bleeder valve now has plenty of room, no interference at all... another method of gasket adhesion....lol RS done... also touched up the coolant hose clamps after installation...I painted them off the hoses, but they still got marked up on installation..still more to do...
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 07-11-2017 at 08:26 PM. |
07-11-2017 | #263 |
Looking good Tom
Dave Quote:
07-11-2017 | #264 |
07-15-2017 | #265 |
Trying my experiment on the TB with the Dry Moly Lube instead of the dag. Not having the success and results I was looking for, I decided to give this a try. After applying several coats, there is still some day light around the blades. I am going to try to brush it on those areas and see what happens. I may also use the dag in addition to the moly lube just on the bore surface in the blade area and again see what happens...
Taped up the bore area so the lube wouldn't be sprayed all over. This may be a longshot and not work as planned. But you'll never know unless you try it.... experimentation at its finest..lol We shall see.... 1500146892575.jpg 1500146910766.jpg 1500146954741.jpg 1500146979089.jpg 1500147006024.jpg Sent from my SM-G935P using ZR-1 Net Registry mobile app
07-15-2017 | #266 |
Should have bought stock in painters tape
07-15-2017 | #267 |
Cruise night!
Tom I am saving you a spot. |
07-15-2017 | #268 |
I do go through it....lol enjoying a fun time.....
Thanks John, I am on my way.....should be there in a few........
07-15-2017 | #269 |
Hey?
It's raining there? Tom, be careful, Big John just wants to see ya get your car all wet! 😋 He tryed to get me too... |
07-15-2017 | #270 | |
I think John is just trying to get me to get the Z back together sooner than later
