Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 Member Rides
Old 07-31-2023   #261
f2892704
Default Re: 1995 ZR-1
Damn super clean cars
f2892704 is offline   Reply With Quote
Old 08-03-2023   #262
JimZRyd
JimZRyd's Avatar
Awesome collection of Z's! I'm on Marc's list...planning a 385 build
Jim Zorgias
1994 ZR-1 Admiral Blue/Black #245
1996 Callaway Supernatural 450
1990 Callaway Supernatural 490 / CR-1 #7
JimZRyd is offline   Reply With Quote
Old 08-04-2023   #263
Demps
Demps's Avatar
Thanks Jim. I really like my 385. Lot of folks are saving the crank delay & cost and doing an offset-grind crank. Not sure how I'd go if starting from scratch. Can't wait to hear about your progress...once you do it, you'll wonder why it took so long.
Ted
Old 08-10-2023   #264
Demps
Demps's Avatar
I may have found the perfect C4 ZR-1 combination. The Red415 has been straightened out. Marc adjusted the tune and other small issues. The car literally drives like a 600hp stock ZR-1. I've always been a B&B fan, but their resonance inside the car with an x-pipe is significant. I've finally gotten old. This car's Corsa is quiet inside. The 4.10 gears, short shifter (BB), coilovers, and Brembos really complement its power and drivability. Pioneer nav, Bluetooth, and sound are exceptional. Stock cams and dual mass flywheel mask its inner beast. 96 deg ambient driving was normal! WOW! Haibeck does it again.
Ted
Old 08-10-2023   #265
JimZRyd
JimZRyd's Avatar
Awesome build Ted! That's one beautiful red Z! The way you matched the color on the plenum is striking!
Jim Zorgias
Old 08-10-2023   #266
Demps
Demps's Avatar
Jim,
A little too much red...but I bought it that way. Used the money to redo it gray to make it run better.
Ted
Old 08-10-2023   #267
JimZRyd
JimZRyd's Avatar
Originally Posted by Demps View Post
Jim,
Ted
If Marc refinished it, I'm sure it's a beauty!
Jim Zorgias
Old 04-06-2024   #268
1993C4LT1
Wow
This thread is gold.
1993C4LT1 is offline   Reply With Quote
Old 04-07-2024   #269
Demps
Demps's Avatar
Early morning drive. Clear skies and 60 deg. Black car has 435 rwhp with 4.30s. Yellow has ~550 rwhp with 4.10s. Quite exciting.
Ted
Old 04-07-2024   #270
1993C4LT1
Beautiful. I have fm5's on my 96 ce lt4. Have a set of fikse aro's as well. I might rebuild the rears to fit my 92 zr-1
