11-17-2010 | #251 |
Re: LT5 Assembly Project
The IH that came with were not siamesed....I will be Siamesing the IHs and Plenum. I am shooting for 500hp(crank), but with that the car will be 3150lbs so I can get by with alittle less if needed, the 2ndry port is fine....primary could use some, but I am not going to puruse it.
Ultimately, this engine(a spare from 90-702) will go into #966.....I will then rebuild #966/port heads, and reinstall it in the car.....shortblock from #702 will probably then go up for sale.
11-17-2010 | #252 | |
Anywayz...another 500+ hp FBI entry. How cool is that!!?? P.
11-20-2010 | #253 |
Some Clarity on Lifters
Looks like the INAs are AM.....421 000 110 HT-2236 Lifter is 35MM Diameter 27MM Height INA 421 000 110 is 35MM Diamter and 36MM Height.
11-20-2010 | #254 | |
I'm planning on using the same light weight INA lifters as you have with stock exhaust and SGC Stage 1 intake cams. Where is a good source for 35mm bucket lifter shims (lash caps) for 8mm valve stems? Last edited by Jagdpanzer; 11-20-2010 at 08:51 PM. Reason: corrected to 35 mm lifter |
11-20-2010 | #255 |
11-20-2010 | #256 |
Alittle note from Pelican Parts Forum on INA lifters, which I believe are the same as ours(Porche 928/944)
http://forums.pelicanparts.com/porsc...ml#post5570254
11-20-2010 | #257 |
Post on Pelican Parts not to use the INAs, but to use the VW Lifters
Can you go to a solid lifter: http://www.034motorsport.com/engine-...ors-p-629.html
11-20-2010 | #258 |
In terms of the Cam failures we have seen, maybe we need to touch base with these guys, they use the sames lifters/followers.....and they seem very confident in their regrinds:
http://www.928motorsports.com/parts/camshafts.php
11-21-2010 | #259 |
Lee,
Those are not the same p/n INA buckets that I have, but similar in appearance. There are several different ones looking about the same, but varying in weight and application. The lightweight ones are VW/Audi part 050 109 309HBR. The suffix is important. The INA manufacturer p/n is printed on the underside. We tested them to over 8000 on the spintron and saw no adverse issues with the buckets. |
11-21-2010 | #260 |
Interesting Article on flat tappet Cams, explores reason for failures, I noticed that the HBR means the tappet was made in Brazil, wondering if you are going to coat them, I am considering having my lifters coated.
