Old 03-03-2014   #251
Schrade
Default Re: Corvette Museum
Originally Posted by scottfab View Post
There should be no need for multiple "ping"s. A few pings is all that is needed to be registered in the "arp" cache in each server/router along the path. Once in the arp cashe(table) it does indeed "lubricate" the flow in that the DNS lookup for the target no longer needs to be looked up. A better way is a trace route (tracert) command since on most servers the info is kept longer (timeout for data).
There are various incantations of this but the simplest is:
tracert corvettemuseum.org
Then sit back and watch the path your network request takes through all them there pieces of hardware.
Another little secret is to do multiple browser requests for the address. That is if you notice a delay in getting to you target address simply resubmit the address OR "refresh" the page request. It's like punching a hole through a clogged sewer line with a snake
Doesn't mater what browser, what OS, what hardware or what day of the week it is. This works.
You're a little over my head there Scott...
But it seems that once you HAVE the datapath to corvettemuseum.org domain established in ONE browser page, do you HAVE TO establish it again, with more browser pages to the site? Won't that 'clog' your OWN hardware - again, IF you already have the datapath established???
And even if you do NOT, isn't the syn-ack the first order?
Anyway, they did WELL dropping the '93 rubber down. Well done guys!
Wonder why they didn't drop it on to a dolly?
Anyone know where they drove the Z to? None of the other cams showed a truck outside the museum, and none showed the Z outside... Is it inside the museum elsewhere???
Originally Posted by Racinfan83 View Post
Ok guys I'm gonna really sound like a dumb here - but I have absolutely no idea what you are talking about
No idea what Linux or Unix is. I run Vista on a 5 yr old HP laptop. What is a "command line interface"? Or a "tracert"? Now the "multiple browser request" deal I can figure that out. Just keep hittin "refresh" on the webcam page correct?
ed.:
I'm not sure if Scott was agreeing with me there racinfan, but either way, to get a command line in Windows, click Start, then 'Run, and in the dialogue box, type cmd.exe. That give a Command Line Interface. Type ping corvettemuseum.exe. Your computer will send a rudimentary signal to corvettemuseum.org. Kind of like saying 'Hello'? Are you there? "Keep Talking To Me here".
Linux is a free operating system. Better than Windows is EVERY WAY. You can try it without changing your own PC. Download it [Ubuntu 12.04 LTS (Long Term Support) ], burn a CD, and re-boot up from CD.
Old 03-03-2014   #252
Racinfan83
Well Miss Ruby don't look so good....
Old 03-03-2014   #253
Schrade
Are you at the museum racinfan? Anyone else on the boards there?
Old 03-03-2014   #254
scottfab
scottfab's Avatar
I think this is from Webcam Skydome 2
Here is a video of one of the recoveries:
https://www.youtube.com/watch?v=8SYXGtbAe4w
And since there seems to be a path resolution issue to the Webcam Skydome camera, here is a direct link for tomorrow
if the same should happen:
http://ncm-skydome.click2stream.com/
Scott
Old 03-03-2014   #255
Fully Vetted
Fully Vetted's Avatar
I can't get a feed from that link anymore.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 03-03-2014   #256
Fully Vetted
Maybe they will crank up production of some windshields for us. They will need some if they're going to restore them back to original.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 03-03-2014   #257
scottfab
scottfab's Avatar
You can use this direct link:
and also
http://ncm-skydome2.click2stream.com/
These links should be good tomorrow IF the path from the NCM webpage fails again.
Scott
Old 03-03-2014   #258
Racinfan83
No I got this pic from the NCM Facebook site.
I will try that command line thing. Thanks for explaining!
Old 03-03-2014   #259
USAFPILOT
USAFPILOT's Avatar
ruby red LT1 is jacked up
Old 03-03-2014   #260
Blue Flame Restorations
40th is mostly cosmetic. Body panel replacement on a C4 is nothing compared to most other generations of the marque.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
