Old 11-05-2010   #231
Toyvet1
Default Re: LT5 Assembly Project
Okay you two play nice, lol....
Toyvet1 is offline   Reply With Quote
Old 11-06-2010   #232
Nice machine work! You FBI guys are lucky that you have a shop close by that you can trust.
Good luck with the project Lee. It sure looks like it's going to be sweet!
Old 11-07-2010   #233
Filled up the Shopping Cart at Jerry's to see how much more I need to have everything ready. This is going to be pretty much built with all Gaskets from Jerry.......
Rod Bearings from Jerry here
Have stock pistons and liners coming from Kevin
Pete got a straight valve to me, thanks Pete.
Calico coated bearings are on their way home.
Pick up heads next week.
Getting closer, need to get the crank checked....also need cam bolts.
Are the rod bolts OK to reuse?
Old 11-07-2010   #234
Polo-1
With the under cut shank on the stock bolts I would say no, for me. I'm sure they could be reused in a pinch. I think Marc has the ARP replacements.
Old 11-07-2010   #235
lbszr
lbszr's Avatar
I've used ARP's from Marc, and they're reusable if they are installed with a bolt stretch guage.
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT]
[FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT]
Old 11-07-2010   #236
Holy $hit $195 for rod bolts....hope that adds 10HP
Old 11-07-2010   #237
Polo-1
try $1360 for head studs
Old 11-08-2010   #238
Its $90 to flow test these.....is it worth the $ or will I only get the....well there is such variance in flow benches, etc?
Thoughts....
Old 11-08-2010   #239
Thoughts....
Why not flow them against the GVDs I have then you'll have a good benchmark. I'm curious about mine anyway. See if he'll cut a deal on 2 sets of heads. I think Pete has a set done at his place. That would be cool to compare the three.
Old 11-08-2010   #240
Polo-1
Big Dogs GVD Mono runner 334cfm @ 450 lift. Stock Valve
