Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 ZR-1 Prototypes
Old 02-03-2010   #221
1989ZR1#74
Default Re: 1989 ZR-1 Pilot #004 Thread
John, What was the criteria for assigning an EX#? For example, your snake skinner had a standard VIN: #081 but Snake skinner II had EX6153? Thanks Eric
1989 ZR-1 #04 Pilot, Advertising/PR Campbell-Ewald S9YKH1
1989 ZR-1 #58 LT5 only
1989 ZR-1 #74 Unreleased Production / PR Dept 9PR110
NCRS #3,182 SACC #2,420
Member Corvette Museum
Corvette Forum: "ewjxn"
2009, 2010 Gathering Attendee
1989ZR1#74 is offline   Reply With Quote
Old 02-03-2010   #222
Originally Posted by 1989ZR1#74 View Post
At least 6...
004 (DRM/Saddle w/saddle seat backs)
at least 4 that went to Europe (Car labeled #6 DRM/Saddle w/black seat backs)
078 (DRM/Black)
Can you scan the picture? What color is the interior?
The picture is of the back of the car and theres no interior shot.
Old 02-03-2010   #223
1989ZR1#74
Hmmmm... can you take a pix of it? Any quality will do.
Old 02-03-2010   #224
Heinrocket
Vehicles with a VIN usually meant a pilot or production vehicle. The EX number, if applied by the plant meant that it was some kind of prototype. Experimental! These vehicles had to be paid for out of budget immediately and would be used for some kind of testing and presumably would never be sold, but would be scrapped out.
Some VIN vehicles were turned into EX vehicles when enough experimental parts were installed to where the vehicle would become experimental. Discpline on this was not that great though
Heinrocket is offline   Reply With Quote
Old 02-03-2010   #225
Heinrocket
So Snakeskinner ll was never a pilot but was a prototype. It probably started as a 1987 or 1988 car.
Old 02-03-2010   #226
Heinrocket
Now that I said that, it could have been a 1989 that was turned into an EX number, but i thought it was an earlier car than that
Old 02-03-2010   #227
Tyler Townsley
I determined #004's internal GM number today. Corvettes White was kind enough to share the fragments of #010's build sheet with me and I just realized that the order number for #010 appears to be it's P number:
P9Y066
Using that info I went back to the fragment of #004 build sheet and found this in the order number:
So I think S9YKH1 is its internal number 9 = 89 Y = Corvette,
S = Sales?
KH1= King of the Hill 1?
Any thoguhts? Eric
The P mumber is what GM useed to kep track of these cars. If there is info filed it will be filed under that number.
http://deliquescence.net/~tyler/prototype/87_build.jpg
This is a copy of what was in the frame of mime which means it was on the frame build part of car as it went down the line. When the body was dropped on the frame a worker put the 'extra' sheet in the frame. Eric you can get a copy of the build sheet from the NCM.
On this document you can see all the numbers tied togeather on one page. The ex # and p# in the KOH line and the actual assembly line build on the top right. I have never seen the rpo codes lined out like this except on the 88 prototypes like mine, I can only assume the build computer did not have them programmed as options yet.
Tyler
55 Polo White (Project)
61 Jewel Blue (Sold to buy above)
66 Nassau Blue
68 Torch Red
88 ZR1 Blue
90 ZR1 White
Old 02-03-2010   #228
Tyler Townsley
The telling number is the frame vin that can then be checked against this.
http://deliquescence.net/~tyler/prot...production.jpg
That will tell you what the car started out as off the production line.
Tyler
66 Nassau Blue
68 Torch Red
88 ZR1 Blue
90 ZR1 White
Old 02-03-2010   #229
Heinrocket
After the cancelation and move to the 1990 MY there must have been 50 89 ZR-1s lying around. Has there ever been that many unsaleable "project" cars to play with? It seems like so many "fun" EX cars came out of that group. In the long run did having those "Engineer Units" available make the ZR-1 project better? Eric
once it was decided not to sell these cars, it certainly did give us the largest group of project cars imaginable. having them did help to make sure the 90s were as good as they could be.
Old 02-03-2010   #230
1989ZR1#74
Tyler
I think P cars were not mutually exclusive. #074 was 9PR110. No "P" nor Y. This car is an "S" I am sure GM had a S group. So it's "P" number is S9YKH1 if that makes any sense. My space on the build sheet does not have the same info yours has. No EX# No P number. THis car belonged to the Chevy Photography/Campbell-Ewald. A whole different group. (which is probably why it is still here. John and his guys seemed to chew up those P numbers. Not to many of those left anymore but at least 5 PR cars are still here.)
