Old 05-19-2014   #211
Locobob
Default Re: Locobob's Interior Mod Thread
Also rewired the connectors which feed the DIC to incorporate the changes made in my custom DIC display - a mock up of which can be seen in the first pic. Basically all I had to do here is cut three wires and move them to connector slots which are conveniently unused on the 91 DIC display.
Robert
Old 05-20-2014   #212
Locobob
The window in the custom DIC screen is for a tire pressure monitoring system. Think I'm going to pull power for this off the I CONV PL fuse which is under dash on the passenger side, it's hot in run. Need to find a ground to tap into near this location, any suggestions?
Robert
Old 05-20-2014   #213
Schrade
Re-pinning sockets. Been there did it (desktop PC) YUK.
Good work on it
Old 05-21-2014   #214
Locobob
Good work on it
Wasn't too bad of a job, except the terminals I found don't want to lock into the connector. I'll have to watch them to make sure they don't back out when I push the pin side in.
Robert
Old 05-21-2014   #215
Schrade
How did you unpin the sockets?
Got a sputnik like Darby has there?
Old 05-21-2014   #216
Locobob
I cut the wires and put on new terminals, had I known there was a tool like that I probably would have used it.
Robert
Old 05-23-2014   #217
Locobob
Making some real progress now. I've been vexed by dimmer issues for a while now and I kept playing with the stereo connections thinking that the problem was stemming from there. Finally I got smart and put a multimeter on the gray/blk dimmer wire coming off the seat controls... it only read about .6 volts on low and just over 1 volt with the dimmer all the way up. Turns out it was my headlight switch causing the problem. I bought a 92-93 headlight switch off ebay so that I could start with the black finish which blends in better with the carbon fiber coating, apparently it had some internal problems. I swapped the guts of the unit with my original headlight switch and no more problems The stereo now dims like it should running off the incandescent light control (gry/blk) and I'm getting proper voltage at the seat control dimmer wire. Here is a little video of me testing a few things. You can see the stereo dim as well as my custom heated seat switch panels and the amber LED strips I have under them to provide lighting. This is the first edition of my seat switch panels, they made the lettering too big so I have another set being made up. My lettering fill paint is also not quite as orange as the factory so I'll probably try some different paint next time. The annoying red light that comes on when looking at the stereo is a red LED I'm testing in the DIC display - more on that later.
Click on the pic below to see the video
Robert
Old 05-23-2014   #218
Locobob
Also I need a favor from the 91 owners here - what lights up on your DIC display when you first turn the key? I'm not seeing anything from ABS active and low coolant (which I moved), and also nothing from the low oil light (which I didn't move).
Robert
Old 05-26-2014   #219
Locobob
My research seems to indicate that the low coolant light does not come on during the DIC bulb test at key on. How about ABS active and low oil? There's got to be some folks out there with 90-91 models that can verify this for me. Anyone..... anyone.... Bueller?.... Bueller?
Robert
Old 05-26-2014   #220
Give me a couple min.. I will go get a pic of my 90
