Old 05-25-2009   #201
Default Re: LT5 Assembly Project
Ordered a new LFT Intake cam and wear strips from Kurt.....so getting closer to moving forward. I would like to complete the engine this winter and have it in the 90 by next spring.
I am guessing that the cam bolts cannot be reused. So I still need to pick up:
1)Replacement pistons and liners...(I have a lead on these, just need to pull the trigger)
2)Rod bearings
3)Cam bolts
4)Washers for head bolts
5)balancer
-The heads need some work
*welding intake ports for a better IH seal
*IH bolt needs to be extracted that broke off inside
I was wondering best way to check valve stems to ensure they are lined up properly and that valves are sealing. I am also wondering what is needed to ensure proper torque specs on the engine bolts:thread chasers, good torque wrench(looking for brand name)etc.
Old 05-25-2009   #202
Also looking for a list of speacial tools that are an absolute necessity:
I have the crank locator tool, Cam pins are easily made.
-Wondering if carter can make the hold downs used to simulate the cam cover?
Anyone have a pic of the oil pump allignment tool?
Old 05-25-2009   #203
carter200
carter200's Avatar
fax me what you need and I'll see what I can do for you 325-625-5795
PS: Saw a balancer on ebay.........
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 05-25-2009   #204
carter200
carter200's Avatar
I was wondering best way to check valve stems to ensure they are lined up properly and that valves are sealing. I am also wondering what is needed to ensure proper torqu specs on the eninge bolts:thread chasers, good torwue wrench(looking for brand name)etc.
Craftsman makes a good "click" torque wrench. You could always "re-lap" the valves in using valve lapping compound to ensure seal. Check with water. Blow out port when done. A heat gun would make sure of water gun, too. Good luck on your project
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 05-25-2009   #205
Polo-1
5)balancer
350 or 368
Also have the balancer too.
Old 10-27-2010   #206
Well its about time to reopen this thread, got my rod bearings from Jerry's gaskets today as well as the valve guide, so my heads will be done shortly.
Motor will be out shortly, now trying to decide...I might rebuild using the #702 block....pull #966 port heads and rebuild it.
Old 10-27-2010   #207
Polo-1
I have a block with fresh torque plate hone 4.010 LA sleeved ready to roll.
Many 350 liners/pistons, 368 4.00 pistons/rings/mod stock rods for 368,heads,cams, intakes, ...........
What do you need. It's going to be a fire sale
Old 10-28-2010   #208
looks like my cylinder liner and piston issues are resolved!
Old 10-28-2010   #209
cool, use the 702, build it up
-=Jeff=- is online now   Reply With Quote
Old 10-28-2010   #210
Polo-1
