Old 04-01-2014   #201
Locobob
Default Re: Locobob's Interior Mod Thread
imho looks somewhat black widowish
That's not really a bad thing for a ZR-1 if you know what I mean.
Robert
Old 04-23-2014   #202
Locobob
Finally got my modified seat brackets back, they should be a nice height improvement. Took about 7/8in off the front and maybe 1/4in off the rear. Had to cut down the rear seat mounting studs a bit for clearance.
Modified bracket in foreground:
Robert
Old 04-23-2014   #203
Locobob
Still playing with some color ideas, here are a couple of my attempts to tie in the red door panels and create kind of a wrap around effect with the red.
Borrowed this idea from Caravaggio as you can see here...
Robert
Old 04-23-2014   #204
Robert,
Wow! The way the car should have come from the factory in the first place. I like the black/red. Actually, like them both.
Old 04-23-2014   #205
I like the zr1 interior but not that diamond tuck look on the console side
Old 04-23-2014   #206
Locobob
I concur, the diamond tuck is not bad when its done subtly but it's too much for me when a contrasting thread color is used.
Robert
Old 05-15-2014   #207
Locobob
I grabbed some red scrap from the upholstery shop and did some very crude mockups, I have decided to go with the red center console surround but the seats are still vexing me.
Robert
Old 05-15-2014   #208
Locobob
Waiting on three different venders for various parts I need for this project, engraving shop has my heated seat switch panels, paint shop has my harness grommets, and sign shop has my custom DIC screen.... arrggg.... hate waiting on stuff.
Robert
Old 05-16-2014   #209
USAZR1
USAZR1's Avatar
[QUOTE=Locobob;201388]Still playing with some color ideas, here are a couple of my attempts to tie in the red door panels and create kind of a wrap around effect with the red.
Photoshop your new Momo Commando to the above and let's see that,Bob.
Old 05-19-2014   #210
Locobob
Working on some more wiring while I wait for stuff from vendors. Here is the radio connector. I cut the gray/black wire which is incandescent illumination and connected it to the dimmer wire on the aftermarket head unit. Then I took the other gray/black and the purple/white which are LED and LCD illumination and connected them to a pair of 1K ohm 1/2 watt resistors - need to find a keyed hot to connect these two. This is per bulletin 238311. Was thinking of possibly tapping into one of the two keyed hots which feed the DIC.
Robert
