Old 06-11-2014   #201
Schrade
Default Re: Where has my DM log data saved to?
Originally Posted by Franke View Post
Wow, never seen that on my car. Voltage is ok then but why the single momentary open loop at initial 1.6-2.4 % tps? It seems as if there is a flat spot on the tps but I think you said you changed it. Correct? Also, have you ever replaced the O2 sensors? One side seems to be lean at idle.
https://www.youtube.com/watch?v=Vl4INfOBUiY @ :36
I just noticed that Franke - that the momentary Open Loop, while it's been in CL for several minutes, DOES CO-incide with the excession of 1.6 % TO.
I'll see if I can replicate that, and get exact data for it...
Old 06-11-2014   #202
Default Re: 1990 Throttle hesistation
Why is the TPS% 1.6 at idle? .61v is high for idle.
Old 06-11-2014   #203
Schrade
It's not idling Dom.
Idle Voltage motor off, Ig ON, TPS is TUNED to 0.54V. Ig ON, motor on, it stays @ .54V.
I'm using a box wrench to bump throttle stop screw, 1/6th turn of the Hex bolt at a time.
And I was doing it SLOWLY, to allow parameters to '0' for that TO %.
TPS voltage, and TO %, in DM, are in pretty tight sync, and are posted in this thread a few pages back.
