Old 10-16-2009   #11
rhipsher
rhipsher's Avatar
Default Re: Life is good.
Originally Posted by jonszr1 View Post
might be your pvc system or maybe your brake booster . my cruize control caused a high idle in the blk cvar. va hose had a little leak
I've got to be at least in the mid to high 12"s right now. I haven't taken it to the strip since I put the Fidanza on and the top end porting. The only way to tell is just to get my but out there and see. My last best run before all this was 13.050@110.32mph. But before I do I'm going to let Corey work his magic and dyno tune it for me. I'm going to head up for the Texas gathering a day early so he can do it for me.
Old 10-17-2009   #12
Originally Posted by rhipsher View Post
But usually when I have a vacume leak my vacume pump will cycle allot and sometimes go nonstop until I find the bad connection. But anythings possible.
A leak in the secondary system will result in the vacuum pump running. However, a secondary system leak would not affect idle, but rather the action of the secondary system.
On the other hand, air leaking into the intake plenum someway will result in a high idle. Other things as well...IAC, etc., but a scanner should help identify issues with monitored systems. Like someone mentioned: ye ol propane trick is easy to do and sometimes isolates a leak, if the propane can be placed next to the leak.
Then again...could it be the tune on the chip??? Just a thought.
P.
Old 10-17-2009   #13
Its running great accept the idle is kinda high. Between 1500-2000rpms. I do think it would benifit from a tune. Its gonna be a while till Corey can make me some Jeals. But I can sure feel the difference especially in the top end.
Might I ask what you did about loosing the DAG? The loss of that stuff will make it hard for the secondary blades to seal their bores at idle, thus allowing extra air to give the higher idle speed.
Maybe a call to Marc might help as he fixed that situation for one member.
Old 10-17-2009   #14
rhipsher
rhipsher's Avatar
That thought has crossed my mind. I thought about lightly coating the inside of the throttle bores with some silicone grease where the plates seal just to see if thats it. I know it's not DAG but it will accomplish the same result. If so then I'll buy some DAG. The throttle cable being to tight could also cause that.
Old 10-17-2009   #15
I assume when you refer to "secondaries" you're referring to the main throttle plates in the TB and not THE secondary plates...yes?
P.
Old 10-18-2009   #16
P.
Yes, the big plates in the T/B. I guess it's a left over (in my mind) from Holley 4BBL days. Hey, does any one remember the Holley 3 BBL?
why don't the 2* head plates cause the same issues? I never saw any DAG in those bores?
Old 10-18-2009   #17
I just had a really dumb thought cross thru my mind....what would happen if you took some graphite powder and mixed it with some rtv black?
sorry. that's proly a dumb idea.
Old 10-19-2009   #18
cward
cward's Avatar
950 cfm. I ran one on an Edelbrock manifold on my 68 Camaro. Engine was L-88 427 which replaced the original 375hp 396. Had a few other things done to the engine and car. My Z finally was able to beat the Camaro's time in the 1/4 when I started spraying. Biggest problem with the 3-BBL was it bogged most engines. I didn't care about that as when I was playing, engine was never below 6K. No bog there. Brute hp and tq. I bought the Camaro new in Oct. 1967 with the 375/396. Lots of fun.
Curtis
cward is offline   Reply With Quote
Old 10-19-2009   #19
Hammer
Hammer's Avatar
Talking Re: Life is good.
Perfect for BIG cams right. I remember drilling the throttle plates on Holleys to get engines to idle with big cams. No idle air bleeds back then.
Old 10-19-2009   #20
rhipsher
rhipsher's Avatar
I talked to Corey today and he says he never uses anything on the throttle body bores.
