Old 10-14-2009   #11
Default Re: Need some ideas.
Originally Posted by rhipsher View Post
I've got everything back together and ready to go. Plug the key in and all the bells and whistles come on as normal. Turn the key and no start. The lights go a little dim when I try to crank it over which is normal. Three things come to mind. Either a problem with the starter. The new battery I just bought is not fully charged. And 3rd I might have gotten the two plugs that are side by side that plug into that device that bolts onto the under side of the plenum swapped. I fully expected at least one thing to prevent start up. Any ideas?
If the lights go dim when engaging the starter, that would indicate the starter selenoid has engaged and the starter is taking current with (poor battery connection, weak selenoid, poor primary connections on starter, or starter problem). The starter could be jammed somehow taking full current but not rotating. It appears that the starter is taking ALMOST full current if the lights go dim. Or the battery is undercharged with not enough voltage to rotate the starter. I would start with the battery and battery connections.
Old 10-14-2009   #12
Didn't Marc have a comment about if the starter was stuck that you could use a 3/8" metal rod & get it down thru the plenum and past the coil tray so it was up against the starter? Then you hit it with a hammer to jog the starter/ or the solenoid loose if it was hanging up?
Just a thought, as it sure sounds like something is eating up a lot of current. JMHO
Old 10-14-2009   #13
rhipsher
rhipsher's Avatar
The reason I suspect the starter is fried is before I removed the IH housings and coil pack I was spaying allot of break clean in that area and of course it all ends up pooling up in the valley. It was probably a good 3/8 to 1/2 deep before I removed the starter and when I saw it I thought Ooooh! I hope that didn't get into the starter. It was a mix of engine oil brake clean and dead bugs. I was going to test the starter before I put the plenum on because I feard that it might have got screwed up with the fluid that was in the valley. I know for a fact that I connected everything. There's only two wires that go to the starter. The big red wire and a small one that connects right in front of the coil pack. How do I test the starter to see if it's bye bye.
Old 10-14-2009   #14
carter200
carter200's Avatar
Take the starter to Autozone and they'll test for free.......
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 10-14-2009   #15
rhipsher
rhipsher's Avatar
Now if the starter is dead is it something that I can pick up locally or is it another specialty item I have to order?
Old 10-14-2009   #16
dbriana
Autozone shows one for $190 including a $70 core charge but may have to order depending on location.
dbriana is offline   Reply With Quote
Old 10-14-2009   #17
rhipsher
rhipsher's Avatar
I just talked to Corey and he said its a very good possibility that fluid made it into the starter. He said it could be stuck and if you've checked the purple wire going to it and its got power every time you turn the key fully then the starter is just not turning. He said parts lady is going to have the best price on them.
Old 10-14-2009   #18
rhipsher
rhipsher's Avatar
WooHoo! I was right. It was the starter. I took the plenum off and unbolted the coil pack and took a 1/2 drive extension and a 3lbs sledge hammer and gave it 3 good whacks in about three different spots. Hopped in and it turned right over. I guess the combination of it sitting for 6 months and possibly getting some fluid in it caused it to stick. But auto zone has a starter for $120+$70 core charge just like you said. If I order it before 2:00pm it will be here tomorrow.I don't think I'll need it unless this starter gets stuck again and leaves me stranded
Old 10-14-2009   #19
rhipsher
rhipsher's Avatar
WooHoo! I was right. It was the starter. I took the plenum off and unbolted the coil pack and took a 1/2 drive extension and a 3lbs sledge hammer and gave it 3 good whacks in about three different spots. Hopped in and it turned right over. I guess the combination of it sitting for 6 months and possibly getting some fluid in it caused it to stick. But auto zone has a starter for $120+$70 core charge just like you said. If I order it before 2:00pm it will be here tomorrow.I don't think I'll need it unless this starter gets stuck again and leaves me stranded Hell! It's only $120 for a tow right.
Old 10-14-2009   #20
you must have been so happy you posted it twice
Glad you fixed it
