Old 10-12-2009   #11
Aurora40
Aurora40's Avatar
Default Re: do these brake calipers and rotors fit our cars
Originally Posted by xxxscimitarxxx View Post
I think l will pass on the deal.....lm sure l can pick up C5 calipers for what lm paying on this uncertain package
Those are one hell of a lot nicer than C5 calipers!
Bob Saveland
Former owner of #2517
Old 10-12-2009   #12
xxxscimitarxxx
they are sweet.....but will l spend another 800 getting em to fit
however....l mailed the guy whos selling em....and he says the pics of the brakes are on a 94 C4
so lm still wondering
xxxscimitarxxx is offline   Reply With Quote
Old 10-12-2009   #13
Jeffvette
Not sure what all the confusion is. They are shown currently bolted up to a later C4.
Those are the 993 Porsche Brembo calipers. They are a radial mount which gives you a bigger cross section to be applied to. They are a 4 piston design.
These bear no resemblance to the Brembo calipers on the current C6 ZR1 which are a 6 piston design.
Old 10-13-2009   #14
scholtmj
scholtmj's Avatar
These look a lot like the Brembo's that were on my car:
Different rotor but the center section looks just as thick. They do move the wheels out a bit but everything fits! Don't be afraid of them at all.
Old 10-14-2009   #15
xxxscimitarxxx
seller assures me of the fit so lm doing it
and they do look pretty......and BIG
Dave
Old 10-17-2009   #16
italian job
These calipers look very similar to my brembo 4 piston calipers.
If these calipers are brembo they will not be a direct replacement, you will need to remove OEM caliper bracket and install a custom bracket (or adapter)
Also, because they are 4 piston design, you must be sure to have enough clearance from caliper outside to wheel inside, if the caliper is too large it can touch the wheel. (But you can also install some custom wheel spacers)
On my 90 zr1 brembo calipers fit very good; I simply installed a custom caliper bracket (and a pair of 13" brembo rotors) and no other mods. The braking performance is much more and not comparable with original calipers.
For example: Brembo calipers taken out from a "Ferrari F40" or from a "Lancia delta integrale evo" will fit very good on c4 zr1. But I think other old supercars too have same calipers as factory installed.
Surely you can switch for a C5 calipers, (corvette central offer a complete C5 kit for $999.00.) but at end C5 calipers are very similar to C4 ZR1 HD calipers. Infact they will fit on a C4 with less or little mods, But I think is a loss of money...
as the heading says......
these are from a C6 l think.....Brembos?.....about a year old.....front and rear but this is the only pic l have so far
got a buy pending for $800
are these a direct replacement or is there any thing else l would need to fit to a 90/92 Z
top and bottom joints etc??
italian job is offline   Reply With Quote
