10-04-2009 | #11 |
Re: What are you using to install harmonic balancer/torsional damper?
10-05-2009 | #12 |
Where'd you get that from...
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
10-05-2009 | #13 |
Prayers offered for your Dad. I hope everything turns out okay.
10-05-2009 | #14 | |
Thanks for the kind thoughts.
10-10-2009 | #15 |
Running into a brick wall with anyone that makes a M16 X 1.0 bolt in approximately 6" length that I think could work with a large washer and nut. All negative results with all the big bolt manufacturers, but I have one quote waiting for a response from these guys: http://www.tacomascrew.com/products
If it works I'll post here. |
10-12-2009 | #16 | |
10-12-2009 | #17 |
I'm sure your local machine shop could whip this out very easily. Or you can buy a M16 x 1.0 die and with some 5/8" round stock (close enough to 16 mm) and make your own.
http://metalworking.mscdirect.com/CG...PMPXNO=1725246 Last edited by Jagdpanzer; 10-12-2009 at 11:05 PM. |
10-12-2009 | #18 | |
Includes seven adaptors for use on a wide range of engines. Adaptor sizes are 7/16"-20, 1/2"-20, 9/16"-18, 3/4"-16, M12 x 1.5, M14 x 1.5, and M16 x 2.0. |
10-12-2009 | #19 | |
10-16-2009 | #20 | |
Clint aka billybaloneey '94 - C4 ZR-1 #445 - Black/Black '05 - C6 silver/black 6sp '85 - C4 white/graphite (almost done) automatic '78 - C3 silver/black (a work in progress) automatic |
