09-21-2009 | #11 |
Re: New option for fuel pump replacement
Just took it for a test drive, ran up to 7K in 4th gear a few times, everything seems to be working well! It's probably just my imagination that makes it feel faster than before, but I'm not complaining!
09-21-2009 | #12 |
Thanks for all the detail on this. Rick |
09-22-2009 | #13 | |
09-22-2009 | #14 |
09-02-2010 | #15 |
A few questions here.
Did you need a new gasket for the sender assembly? What is the part # or application for the new sock? Is there anything else you need to buy before diving into a pump replacement? TY
Tom MovIt Brakes USA [url]www.TFEnt.com[/url] |
09-02-2010 | #16 | |
The sock is the same as stock, the nipple on the pump is the same standard size. Any parts store will be able to set you up with an appropriate sock. Nothing else to buy - as long as you have a way to cut the relief slots in the pump holder, and a few zip ties on hand to secure them once finished. |
09-02-2010 | #17 | |
09-02-2010 | #18 |
I called a resource and a whole new AC Delco sending unit with 2 Delphi pumps is only $275. I am thinking of just getting the new unit...
Thoughts???
09-02-2010 | #19 |
09-02-2010 | #20 |
That's the easier approach, for sure... and you get a new sending unit with it. I went the Bosch route because my faith in the reliability of some of the so-called ACDelco pumps was shaken by my bad experience. Others have had better luck...
