Old 09-10-2009   #11
Default Re: DS Cam Cover removal time cutting step
Originally Posted by DaveK View Post
And how much do you need to jack by?
Great tip
Thank you thank you .....limey
I removed both cam covers from my 1991 ZR1 today in about 30 minutes
I placed one jack under cross member just in front of oil pan with 12 inch long 2x6 as cushion. I placed second jack under forward corner drivers side of oil pan with shorter 2x6 as cushion. I removed drivers side engine mounting nut and jacked drivers side of engine up maybe 2 to 3 inches more or less. At that point I could get my 3/8 drive extension with 40 torx over the top of the brake booster and removed the two lower torx cam cover bolts to the rear of the cam cover
Keep as much pressure (pushing into the bolt) on the torx as you can while breaking the torx bolt loose.
I removed the power steering pump and reservoir (three bolts accessed through the power steering pump pulley) at the front of the drivers side cam cover so I could get at the 3 smaller torx bolts on that end. I removed the AC/heater box cover (5 screws) at the rear of the passenger side cam cover so I could get at the lower torx bolts on that end.
Old 09-10-2009   #12
limey
I placed one jack under cross member just in front of oil pan with 12 inch long 2x6 as cushion. I placed second jack under forward corner drivers side of oil pan with shorter 2x6 as cushion. I removed drivers side engine mount bolt and jacked drivers side of engine up maybe 2 to 3 inches more or less. At that point I could get my 3/8 drive extension with 40 torx over the top of the brake booster and removed the two lower torx cam cover bolts to the rear of the cam cover
I removed the power steering pump and reservoir at the front of the drivers side cam cover so I could get at the 3 smaller torx bolts on that end.
Glad it worked out for you, looks like all the questions were answered in that one response.
Should encourage others to now think about refinishing their top end, no reason now why you couldn't remove both cam covers and plenum assembly in 1 hour or less, then send off to the powder coater of your choice.
All i can say is, i had an epiphany.
limey is offline   Reply With Quote
Old 09-10-2009   #13
Re the powder coaters...Yeah, I believe you just boosted their biz quite a bit! One of the best tips of the year, I recon!
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 09-11-2009   #14
ShawnZR-1
ShawnZR-1's Avatar
Oh, SON OF A *****! Now you tell me!
I'm always looking for easier ways to do things and this method NEVER even dawned on me. Could have saved 10 hours of PIA work over the last year alone!
Thanks Limey!!!
1991 Chevrolet Corvette ZR-1
ShawnZR-1 is offline   Reply With Quote
Old 09-11-2009   #15
bdw18_123
That's a very nice tip! I'm gonna file that one away in my brain. That's the kind of stuff I usually come up with, because I refuse to do it the hard way unless I really have to.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B]
1990 Corvette ZR-1 [/B][I]
White/Flame Red, #2299, mostly stock, 144K miles.[/I]
-Cams timed to the '93-'95 405HP LT5 stock timing.
-IAT sensor relocated to below front bumper.
-Haibeck hoops installed in airduct.
-OBX cat-back exhaust.
[COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR]
1993 Corvette Coupe
Black/Black, 6-speed
(SOLD - October 2009 :hello:)
