09-09-2009 | #11 |
Re: Rear Bumper Molding Question
I've been thinking about this and as having a little experience in plastics. If the main varianble in the part is in width (distance from the license plate opening to the corner) could'ne one use a donor piece and add length? It would be easy to add a section using quaility glues, scab a piece on the back, and then fill any inperfections with good plastic putty and paint. No one would ever know....
I'm going to try and find some cheap pieces from junkyard and experiment a little. |
09-09-2009 | #12 | |
That might work, but like I said, I am pretty sure the Narrow body cars had the Rub strip molded into the bumper. does anyone have a good picture of the trim itself? I wonder what it would take to make them.
09-09-2009 | #13 |
The trim from the doors back are separate pieces.One positive here is the door trim are not ZR-1 specific.I know this,I used one from a base car.
09-09-2009 | #14 |
I have also mentioned making it from aluminum on a CnC.
Make it solid on the back side and drill/tap holes for the hold down screws. Same for plastic make it solid plastic and use lag screws like our tail lights from the back side. Rhipsher don't you have access to a CnC? Pete
09-09-2009 | #15 |
I know all the pieces on a ZR-1 are separate.. is that true for 91-later narrow body cars?
09-09-2009 | #16 |
09-09-2009 | #17 | |
So the 91-95 ZR-1's have separate, removable trim pieces for the front, rear and side gills? On the '91-96 standard C4's, the trim on the front bumper, rear bumper & side gills is molded in and not removable separately from the main piece. Only the door trim piece and the small section in front of the rear wheel is removable.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B] 1990 Corvette ZR-1 [/B][I] White/Flame Red, #2299, mostly stock, 144K miles.[/I] -Cams timed to the '93-'95 405HP LT5 stock timing. -IAT sensor relocated to below front bumper. -Haibeck hoops installed in airduct. -OBX cat-back exhaust. [COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR] 1993 Corvette Coupe Black/Black, 6-speed (SOLD - October 2009 :hello:) Last edited by bdw18_123; 09-09-2009 at 04:17 PM. |
09-09-2009 | #18 |
On 91-95 the trim is molded in the front bumper and the fender panels.Doors,short QP piece and all rear bumper trim is separate from the bumper.If somebody has a piece of bumper trim from a base car I can take a look at it see what it would take to modify it for a ZR-1.I would never pay $700 for this part,I would make it out of WOOD before I would let somebody gouge the piss out of me for something that might have cost $100,tops.
09-09-2009 | #19 |
Its plastic It can be repaired, the damn thing only needs to be repainted after the repair and you would never know.
I mean its ok to repair parts, cars ger hit once in a while it happens and with the limited parts available it might be a good idea to repair what you can when you can.
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. Last edited by phrogs; 09-09-2009 at 11:17 PM. |
09-09-2009 | #20 | |
I agree a lot can be done with damaged part, epoxy and sand paper. Of course, if all fails, balsa wood... |
