08-23-2009 | #11 |
Re: The Lift has Landed>>>
Saaaaaweeeet :-) Very nice
How much room do you have under your Z for maintenance? Is the lifts main purpose to give you one more parking spot? |
08-24-2009 | #12 |
Wow! That is a schweeeet addition to your tool kit!
08-24-2009 | #13 |
Hey Michael,
Did you have the link to those step by step directions on the lift setup? Thanks Rich
08-24-2009 | #14 | |
http://www.bestbuyautoequipment.com/...20standard.htm Also the more I read about lift certifications (or lack there of) that came important too...Direct Lift (and Bend Pak lifts) have all the newer certs including 3rd party certifications>> https://www.bestbuyautoequipment.com...les.asp?ID=133
Michael :cheers: [I][SIZE="2"]1990 RED on RED #566[/SIZE][/I] [I][SIZE="2"]WAZOO MEMBER[/I][/SIZE] |
08-24-2009 | #15 |
Yep...a nice addition but once you have a lift (this lift replaces my earlier Snap On scissor style lift) you wonder how you did without one.
Rich...check your email. Height under car... close to 5' when at its highest position (meaning with mechanical locks engaged) My primary intent is to use the lift as a service lift... as of this stage can not get my C6 under the ZR (C6 is kept in my neighbors garage since he only has 1 car), but with some modifications to garage door and ceiling can accommodate the lift as a two car storage lift.
08-24-2009 | #16 |
Hi Michael - That lift looks great! That is every detailers dream to work in a garage with a lift.
[B]Paint Correction Specialist - Portland Oregon[/B] |
08-25-2009 | #17 |
the alum ramps are a great idea. I need to do that
I've been "stacking vettes" and love having the lift. trying to do a garage project for a bit more room. if you all know any good builders and concrete folks in NOVA please let me know. I'd like to have both a 4 post and a 2 post. they both have nice advantages. thanks!
