Old 08-03-2009   #11
Demps
Demps's Avatar
Default Re: Flushing out fuel rail
Cost is $8.28 for a set of 9 o-rings to do the rail/regulator fuel lines.
It's kind of a PITA to do, but as old as our cars are getting, these soft goods need to be replaced. I don't see the need every time, but if it hasn't been done yet, then I would say it's time. Fuel leaks are bad news and can be dangerous and expensive.
I've probably given away 100 sets of fuel block o-rings since starting the gasket business....as a way of saying thanks to customers and because it's a safety item.
Hey, my 415 and SGC 350 are running great thanks to you! A little insurance goes a long way.
Ted
Old 08-03-2009   #12
Running good enough to meet up in Memphis for a little Beale Street boogie?? Say hello to Caroline
Old 08-04-2009   #13
ZR1Vette
ZR1Vette's Avatar
Point taken... anyone know how sensitive the fuel pressure regulator is to 'cleaning' etc? That was my main concern when cleaning the fuel rails.
Michael
:cheers:
[I][SIZE="2"]1990 RED on RED #566[/SIZE][/I]
[I][SIZE="2"]WAZOO MEMBER[/I][/SIZE]
Old 08-04-2009   #14
DTZ ZR1
Did flush the rails out and put the new injectors in with no problem. Actually was easier than I thought it would be. Now after reading some of the post I think I should change all the o rings out before I put the plenum on. Proably would be cheap insurance.
[FONT=Times New Roman]DT[/FONT]
[FONT=Times New Roman]'90 Red ZR-1 #2300 LT-5[/FONT]
[FONT=Times New Roman]'85 Bronze (Almost complete)[/FONT]
DTZ ZR1 is offline   Reply With Quote
Old 08-08-2009   #15
DTZ ZR1
After flushing fuel rails I replace the O rings which I received for Jerry's gaskets. I was easy and I put the rail and injectors in the car. Put the coil packs and wires the I received for Jeff. Waiting for PCV hoses from White Racing to finish the job and hear her come to life again. Thanks for all the help.
DT
