Old 08-04-2009   #11
Default Re: Speakin of "running rough"...
I'm not saying it IS a head gasket, just that it might also be a possibility since head gaskets have a greater incidence of failure in the LT5 than valves or piston/rings, under normal conditions. The other less frequent possibility is for a secondary butterfly shaft screw gets ingested.
Butterflies...BUTTERFLIES???? WEE DOAN NEEED NO STEEEEKING BUTTERFLIES!!
Parts that don't exist seldom fail, and they don't cost anything. Such is the case with my secondaries. Couldn't be happier in that regard! But! indigestion is certainly what #8 has. God willing and the creek don't rise, gonna give the pull a hard charge - or at least get as far as I can go in one weekend - assuming nothing simple (read: non-mechanical) surfaces (but I doubt it!).
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 08-04-2009   #12
blackjack
Unhappy Re: Speakin of "running rough"...
i've been thinking about a 368 too,since i've got the pistons/no sleeve,but nobody around here wants to touch that motor,except a mustang guy,and chicago is soooooo far from here
bj
91/1735
Old 08-04-2009   #13
P.
Did you count your screws Paul? Odd numbers are bad news buddy!
Old 08-05-2009   #14
Jerry,
I thought of that. When I did mine I counted an odd number. PANIC! Found it on the bench.
Old 08-05-2009   #15
Yeah, I sweated some bullets on the first couple. After that I placed my magnetic "grabber" right on the butterfly as I removed the screws...Just in case. At least no butterfly screws went "south". AND...I drove it for about 600 miles after I put the plenum/IHs back on, and she ran like a scalded dog - no missing.
Thinking back tho, on one of the last times out before putting the headers on I went to down-shift and missed a gear - pegged the tach for just a second. I wonder... It will be interesting to see what's going on. I'll take some pix. At this point I'm not dreading anything - just itchin' to get in there and see whazzzup!
P.
90 #1202
Sans secondaries
Old 08-05-2009   #16
Several companies that rent bore scopes Paul, that might be an option.
