Old 07-28-2009   #11
Default Re: Rear Spring issue
Originally Posted by 32valvZ View Post
So I found a spring from a 96 CE vert with 12000 miles on it. The rate shows 39.9 N/mm My Z has one thats showing 33.0 N/mm Will this work ok with the FX3?
TIA
Yes it will work, it will give a bit stiffer ride though
Old 07-28-2009   #12
32valvZ
32valvZ's Avatar
EXCELLENT!!!
Old 07-28-2009   #13
Another option is coilovers. And will lower the car as you wanted in the long run.
Old 07-28-2009   #14
Yep, I agree.. I still need to do the rears.. I am planning on this winter..
(When I fix the brakes, GC)
Old 07-29-2009   #15
32valvZ
32valvZ's Avatar
Lotta dough right now though...... you guys have any ideas on where to get the spring bushings? I prefer rubber, but I'll go with poly if need be.
Old 07-29-2009   #16
Jeffvette
I may have mine laying around some place. They were pulled off when I went to coilovers.
Part number is 10252518. Discontinued.
Old 07-29-2009   #17
32valvZ
32valvZ's Avatar
what about poly, anyone making them?
Old 07-29-2009   #18
Jeffvette
Yes, they make poly. I think you can buy them separately. I may have some of those as well.
Old 07-29-2009   #19
Jeffvette
Take your pick John.
Stock on the left, poly on the right.
Old 07-29-2009   #20
32valvZ
32valvZ's Avatar
I'll call you tomorrow! I am gonna buy the spring I found and my bushings are shot.
