Old 07-29-2009   #11
ALZR1
Default Re: Crankshaft plug...
Do you think I should put some epoxy around the edge to make sure it is still sealed?
No that won't work.if you have developed A leak,then you'll have to replace
the plug.
AL.
ALZR1 is offline   Reply With Quote
Old 07-29-2009   #12
flyin ryan
flyin ryan's Avatar
Won't hurt to put some sealer around it now but as ALZR1 stated, if it 'Has' been disturbed then it's pretty tough to seal externally. If you think you might have disturbed it Lee, & want to try to seal it, what I would use is Green Loc-Tite (can't remember the number 548 maybe...?) couple different kinds of Green, basically it's a stud & bearing mount that's designed to flow into parts that are already assembled. Best way would be to stand the crank on end, short of that I'd heat up the cup plug in the crank a little with a heat gun, give it some Green, then rotate the engine so it flows 360º around the plug. Can't hurt .
Old 07-29-2009   #13
does not appear it moved, at all so i am not going to mess with it.
Old 07-29-2009   #14
65ZR1
A friend was replacing his pilot bearing in a 90 LT5. I warned him about the plug but he must have forgotten. If it leaks, it will leak a lot! We didnt have time to find another plug so we machined up a pilot bushing with a blind hole. Worked great.
65ZR1 is offline   Reply With Quote
Old 07-30-2009   #15
Scrrem
Scrrem's Avatar
I haven't done this excercise yet, but may have it coming this winter....does anyone have a pic of this plug?
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
