Old 07-28-2009   #11
Default Re: Clutch Slave/Master Cylinder
Rhino Master Cyl
Dorman Slave Cylinder
Honestly I took the slave off a 2nd time to tighten a line and it went on much easier....it is much larger than the OE and a tight fit, but the slave rod compressed much easier the 2nd time.
Do you have a new line?
Old 08-01-2009   #12
bldavis11
No new line. Just need to replace the slave, and might as well go after the master while the system is opened / blead. It doesn't look like any of the parts of stamped steel any longer... either plastic or cast. Were the parts quality parts?
bldavis11 is offline   Reply With Quote
Old 08-01-2009   #13
Master seemed the same quality as OEM, the Slave seems ok....jsut different as it is cast.
Old 08-01-2009   #14
bldavis11
Good info. I'll go with the Rhino for the Master. Maybe the Delco for the slave then?
Old 08-01-2009   #15
rhipsher
rhipsher's Avatar
The cast iron one is a heck of allot easier to bleed because the bleed screw faces the ground instead of right up against the tunnel. And all of the slave rods are interchangable with eachother.
Old 08-01-2009   #16
bldavis11
Well due to shipping charges, etc. I wound up purchasing both the Rhino master and slave. I'll let everyone know if these work out okay. Total cost with shipping was ~$110.
Ben
Old 08-08-2009   #17
bldavis11
Ben
The parts arrived a couple of days ago. I'll get around to putting them on the car here in the next few days. Both seem to be fairly well made, though they are cast (as expected).
