07-15-2009 | #11 |
Re: C6 Z06 wheel/tire
I guess I jumped the gun.
I read the thread and saw Locobobs pics. I see what you mean USAFPilot - It seems rear looked good but front sticking out could be an issue. Not only cosmetic but could also create problems for ball joints, in my opinion. |
07-15-2009 | #12 |
Here's someone that already did it.
07-16-2009 | #13 |
I like it If I could find a set cheap enough I think it would make a nice back up-change up
07-16-2009 | #14 |
I don't know, I think the back is too much wheel..
i think 18s all the way around would be the max I would do
07-16-2009 | #15 |
Keep in mind that the Z06 rims are 12in wide as opposed to 11in. A .5 in spacer provided enough clearance inboard but looked slightly tucked in outboard. A .6 or .7in spacer would likely be ideal for rear fitament.
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
07-16-2009 | #16 |
You can buy aftermarket 56/57mm offset 18x9.5's for the front, they are a bit heavier than OEM though.
07-16-2009 | #17 |
07-16-2009 | #18 |
