Old 07-13-2009   #11
Hammer
Hammer's Avatar
Talking Re: Traveling ZR-1 New Owner could use some help
Looks like you made it to VA.
Old 07-13-2009   #12
Hammer
Hammer's Avatar
Some comments over here Dave.
http://zr1netregistry.com/forum/showthread.php?t=9121
Old 07-13-2009   #13
mgbrv8
Default Re: Traveling ZR-1 New Owner could use some help
The fan doesn’t seem to have much velocity it stays at about level 4 or 5 and doesn’t go fast even on 10. It might be a high speed fan relay. My dad and I are also toying with the idea that it might be low on r12 and icing in the expansion valve causing the evaporator too ice up too. I am comparing it to my 84 vettes ac which has been converted with r134 and its no were close too it in speed and cool.
Dave
Old 07-13-2009   #14
HIZNHRZ
The advantage of Tonys Corvette Shop is he is likely to have any parts that might be needed. He often requires you to make an appointment far in advance. If you tell him the situation, he is likely to help you out. After rush hour, Gaithersburg, Md is about a 40 minute ride from you. Contact info can be found at:
http://tonyscorvetteshop.com/index.aspx
Old 07-13-2009   #15
Scrrem
Scrrem's Avatar
Originally Posted by mgbrv8 View Post
Hi guys I am the one traveling. It would be great to meet up with you guys if possible and ask a few question and check a few things. Or if that isn’t practical maybe you could recommend a A/c repair shop or a shop more familiar with ZR1s. I am in Woodbridge south west of the loop 495.
Dave
956-451-6778
Dave, I don't know sqat about A/C but if you are in Woodbridge, Coopers Corvettes (703) 445-1483 is not far from you in Dumfries, about 10 miles south. The have done some work for me and have done good work.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 07-13-2009   #16
Z Factor
Z Factor's Avatar
Smile Re: Traveling ZR-1 New Owner could use some help
Hello Dave, and welcome to the forum.
Old 07-13-2009   #17
mgbrv8
Thanks Z
Dave
Old 07-13-2009   #18
fred
fred's Avatar
Your symptoms usually means a bad blower motor. They are cheap and available at any discount auto parts store. There could also be plugged airways or non opening doors. I'd go with the motor.
fred is offline   Reply With Quote
Old 07-14-2009   #19
Vette Guy
Vette Guy's Avatar
Dave,
If you are still in VA, send me an email at vette_guy@yahoo.com I'm off this week, live in Alexandria, and can assist.
Vette Guy is offline   Reply With Quote
Old 07-14-2009   #20
mgbrv8
Ya my number is 956-451-6778 I am in woodbridge if you want to meet up some time send the name or the address of the place and my Dad and I will see you there I stopped at cooper corvettes and they topped off my r12 so now it dosent freeze up and the fan blows better.
Dave
