#11 |
This is what Greg is looking for.
#12 |
![]() Join Date: Jul 2007
Okay, same one GC refers to.
Now, why is that one silver and the one in my car is all Black?
#13 |
![]() Join Date: Aug 2006
Yes, it is the dual hard lines and hoses. Sorry, I can't post a picture maybe GC can if I send him one. It is leaking at the crimp of the hose and metal pipe. Similar to how the oil cooler hoses leak. Surprisingly, the nipple which is plastic is fine. The nipple is the usual weak spot on these rigs.
#14 | |
which crimp end is leaking? end closer to the heater core? I wonder if you could modify the hose to have the -AN fittings..
#15 |
Might could modify, problem is the condition of the metal pipe under the hose. Concerned about rust level. Haven't pulled it yet for good reason. Let's just say it would be easier to do with a new part.
#16 | |
Next question (sorry) both lines bad or just the one?
#17 |
Oh Yeah.. Call Vette2vette.. he just parted out a 90 vette within the last 6mo.. he may still have it
#18 |
![]() Join Date: Dec 2004
I'm not trying to be a wise guy, Greg....but isn't the metal part of the assembly made from aluminium? I would think that if the cooling system received even somewhat marginal maintenance that the metal would be okay to work with.
JMHO. ![]() Tom
#19 | |
#20 |
Thanks for not being sore at me!
I can't remember where I saw / or heard but some one recently had the same issue at the machine crimps or at the plastic ends or both. Marc Haibeck told them to cut the crimps/plastic ends off and use hose clamps to re-configure the whole assembly. I may have over heard that at BG this yr? I saw that piece on e-bay & was thinking of bidding. Then I remembered the answer from Marc. I figured that if it came to it I would just re-run it using heater hose & ideal clamps as a replacement for the entire OE assembly. I know I just suggested the "backyard / shade tree" way, but mine is never going back to the showroom anyway. I'm a second owner too ![]() ![]()
