Old 07-08-2009   #11
Jeffvette
Default Re: Clutch Replacement
Originally Posted by ZR-1nce removed View Post
And I decided that is the lift I am buying after I build my new garage.
Get a two post. Much much much better.
Old 07-08-2009   #12
Scrrem
Scrrem's Avatar
Wow...two post lift....Jim, you my new Best Friend
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 07-08-2009   #13
Aurora40
Aurora40's Avatar
Next up.......Leaf spring.....more details to follow I'm sure
If you want to go coil-overs, I've a set for sale.
Also, just my two cents, you may want to make your next improvement be new tires. Those GS-C's are probably close to 10 years old, if not a lot older.
Nice work on the clutch guys!
Bob Saveland
Former owner of #2517
Old 07-17-2009   #14
xxxscimitarxxx
If you cant fit a car lift in your garage.....dig a pit!....l use a beam across the pit to do jack ups under the car, and adjust my standing height with boards on the pit base....for wheel work l park the car to the side of the pit....maybe not the perfect solution but beats scrawling around on your back
xxxscimitarxxx is offline   Reply With Quote
