Old 07-08-2009   #11
ZR1Vette
ZR1Vette's Avatar
Default Re: Kind gentlemen...need help on shocking issue>>
Good info all...will get a new switch and replace. Would be great if that is the problem as opposed to a damaged wire somewhere between switch and CHMSL.
Really do appreciate the assistance. After switch install will let you know results... will be either or
Michael
:cheers:
[I][SIZE="2"]1990 RED on RED #566[/SIZE][/I]
[I][SIZE="2"]WAZOO MEMBER[/I][/SIZE]
Old 07-08-2009   #12
ZR1Vette
ZR1Vette's Avatar
Well, I have the switch of issue on order (will be to me on Monday)...but with that said my dealer indicated it is a 'discontinued' item and they found a dealer on the West coast that had one in stock which they purchased. Wow..parts are becoming more and more scarce (considering the brake light switch is NOT specific to the ZR-1 but C4 in general)
Michael
:cheers:
Old 07-09-2009   #13
Jeffvette
You can also pick them up at napa or autozone.
Old 07-09-2009   #14
jrd1990zr1
jrd1990zr1's Avatar
Very common problem on C-4s. Sometimes the switch slides in the retainer and doesn't make contact with the pedal. If it has just slid, try pushing it into the retainer so the pedal make contact. I have also removed the switch and cleaned the contacts inside and reinstalled it on my 86 that fixed the problem.
Ecklers and Corvette Central have the switch available too, $10-15.00
Old 07-13-2009   #15
ZR1Vette
ZR1Vette's Avatar
I obtained a NOS ACDelco brake light switch from a 'special supplier'... installed this morning along with changing out all the fuses in the main fuse box (passenger side dash end)... appears the switch was the culprit and all now is working... thanks all for you knowledgeable guidance on this issue
Michael
:cheers:
Old 07-13-2009   #16
Jagdpanzer
Jagdpanzer's Avatar
Glad you got it solved Michael
Old 07-13-2009   #17
LT5-Lee
I stand corrected, I just had a situation where only the brake lights above the window was not working.
An Unarmed Citizen is a Future Peasant.
Something BLOWbama & Hilary are trying to accomplish now at the UN with the "Global Small Arms Treaty"
LT5-Lee is offline   Reply With Quote
Old 07-30-2009   #18
black90
Had same problem. Checked fuses - no problem. Changed all 4 bulbs in high mount light - still didn't work.
Decided it had to be the switch for the brake lights - seems it is a two part switch. Took cover off (the under the steering wheel) and replaced the switch. That did the trick. Have to be a bit of a contortionist to do the job, and it took some time to go through all the motions. It worked and I could get the inspection sticker.
black90 is offline   Reply With Quote
