07-10-2009 | #11 |
Re: McLeod Flywheels-aluminum
Just got the Mcleod Flywheel.....16.5lbs
Bought the Beck/Arnley kit off Rock auto for $111.00 **Pressure plate is Valeo LT-1 Clutch disk on its way $64 off ebay(Thanks Dominic) Anyone interested in the LT-5 Clutch disk that came with the kit let me know....again its a Beck/Arnley kit...pressure plate was Valeo....disk however says Made in China. Asking $40
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 07-10-2009 at 09:37 PM. |
07-11-2009 | #12 | |
07-11-2009 | #13 |
$30 for you jeffy
07-11-2009 | #14 |
Cool
07-13-2009 | #15 |
Anyone know if the Mcleod flywheel requires different bolts?
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 07-13-2009 at 10:31 PM. |
07-13-2009 | #16 |
As I understand it I can use GM LT1 Fbody Flywheel bolts?
07-13-2009 | #17 |
jerry of jerrys gaskets has the lowdown on the bolts
07-17-2009 | #18 |
Can you use a 7/16 1.5 with a thicker hardened washer? Finding bolts is F@#king pain in the AZZ
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 07-17-2009 at 11:19 PM. |
07-18-2009 | #19 |
Distance between the washer and crank is .521" torqued to 25ftlbs.....flywheel thickness is .537.
There is a decent sized tip on the bolt, grind it down and use them or is this too close?
07-18-2009 | #20 |
found 1.25
