Old 08-26-2010   #11
batchman
Default Re: Brakes
In my experience the MC shows failure by slowly dropping the pedal with steady pressure. I've changed an MC trying to cure soft pedal syndrome but no luck. Only fix for me was flushing fluid with the right bleed order RR, LR, LF, RF. Rock Auto has rebuilt MCs pretty reasonable.
Loosening up wheel bearings (constant battle for me) cause pad knockback which also gives soft (actually more like long) pedal. Steel lines help some, the rubber lines are almost certainly degrading by now.
For street/autocross driving I use Ford heavy duty fluid, it's got the best wet boiling point and it's cheap. Once it's been in the car a couple months it's wet. Track driving is a different story.
Good luck,
- Jeff
[/I]
