Old 07-02-2009   #11
jonszr1
jonszr1's Avatar
Default Re: Cooling system bubble?
do you have the stk prom still in your car if you do even with the new rad it will get hot when going slow as the factory setting for the fans to come on is around 223. unless you have the air conditioner on .
Old 07-02-2009   #12
Pqtaces
I don't think the fans are a problem. The fan switch is bad so my guy bypasses the switch and connected the fans to the ignition to come on when started until we can replace the switch (having that done at the same time as the rad). He said the high temp is due to the lack of air flow.
Mind you, I know very little in the mechanical arena so I am putting a lot of faith in the shop. I am taking the car to Guldstrands exactly for this reason as they come highly recommended and are regarded as a top shop. From what I found there are only a handful of good shops here in SoCal and they are the closest to me (only about 3-4 miles from my office).
They have treated me well so far. I took the car in as soon as I bought it to be completely checked over and they only found a few minor things. Cleaning the rads was one of them (replacing the rad was actually my idea not theirs- so it doesn't seem as if they are trying to bleed me).
Pqtaces is offline   Reply With Quote
Old 07-02-2009   #13
Originally Posted by WB9MCW View Post
I agree and Marc's method has never failed me too.
Old 07-02-2009   #14
"I am taking the car to Guldstrands exactly for this reason as they come highly recommended and are regarded as a top shop."
Yep they will get to the bottom of it all -- top shop indeed!
Old 07-02-2009   #15
VetteMed
I already tried Haibeck's approach... so maybe it's not a bubble after all.
Old 07-02-2009   #16
Ccmano
Once the car is at operating temp, turn your HVAC system to full max heat (defrost will do it) If there's no or little heat inside the car you have an air bubble. If you get full heat you have a radiator/thermostat and/or fan issue. Did you remember to turn the heater on when you refilled the system and brought the car up to operating temp.
H
Old 07-02-2009   #17
Good point here -- Mine used to get real hot with the factory chip and the silly high 223 fans on setting (for passing emissions by orig GM design) with my new mod chip the fans kick on at 180 and cool down to 160.
Best part is that even on a humid 95+ Chicago summer day my Z can sit at idle for long periods and never gets above 205 and back out on the road and with a bit of air flow and a mile or so and I am back down to 170.
This is why I never put the big mouth aid dam on -- really no need to -- stock stat as well for me and orig rad too.
Got rid of the dreaded cags too and the performance improvements were great as well.
best mod for the money the chip is indeed.
Old 07-02-2009   #18
VetteMed
H
Plenty of heat... HOT heat. I did run the heater while flushing, BTW.
Thanks
Andrew
Old 07-02-2009   #19
Andy did you try what JeffVette said >>>
Andrew, the gauge is not a linear representation of how hot things are getting. Go into the diagnostic mode on the AC controller by holding both fan speed up and down buttons for 5 seconds, release and -00- should show, use either the up and down button again ad go to -16-. Hit the auto buttun for fan speed. That will give you the coolant temp in C.
Are you running a stock prom chip and dealing with 223 b4 the fans kick on?
Old 07-02-2009   #20
VetteMed
I'm out of town this week so I can't check anything until next week. But I will look into that ASAP and report back with my findings. PROM is aftermarket (Z-industries). I haven't observed the fan-on temps yet.
