Old 06-27-2009   #11
Default Re: Clutch replacement questions
The car is 16.5" off the ground(rocker cover to gorund).....is that high enough to do the work?
Also found out my knock sensor is off, that might be my performance issue at the track.
Old 06-27-2009   #12
Photos of doing the tranny pull >>> http://www.corvetteactioncenter.com/...lutch-job.html
MORE ON TRANNY PULL >> http://www.zfdoc.com/transmission.htm
FOR MY MEGA LINK AND THREAD LIST FOR CORVZ061 (MY BUDDY) FOR ZR-1 MODS AND THINGS TO DO
SEE >>> http://zr1netregistry.com/forum/show...66&postcount=3
Old 06-27-2009   #13
Kb7tif
While your trans is out pop in a new main seal 6$ (driveshaft). Do yourself a favor drain the transmission fluid first.
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Kb7tif is offline   Reply With Quote
Old 06-28-2009   #14
rhipsher
rhipsher's Avatar
Gee! That looks familliar. Hehehehehe!
Old 06-28-2009   #15
diamond zr1
16/1/2 inches,on the floor I could not slide under that/get a lift;;;;
diamond zr1 is offline   Reply With Quote
Old 06-28-2009   #16
Hammer
Hammer's Avatar
Talking Re: Clutch replacement questions
Change the driveshaft u-joints too. Spicer non-greasable if you are racing.
Old 06-28-2009   #17
I have the same problem, di#k gets in the way
Trust me if I can get under there at 260lbs.....so can you
Old 07-05-2009   #18
Since I went with a Mcleod single disk, can I then use a sprung hub out of a 1996 Camaro Z28?
Old 07-05-2009   #19
um, the disc will have the sprung hub..
but if you use a ZR-1 pressure plate and Throw out bearing, then yes you can use the Camaro sprung hub disc
Old 07-05-2009   #20
rhipsher
rhipsher's Avatar
Lee the Mcleod disc should have the springs already in it. This is a CenterForce but It should look something like this. Unless you meant your aluminum flywheel.
