07-03-2009 | #11 |
Re: 92 just went kabloom
Boy Gaffer ur having fun now --
Funny how you were just asking abt tranny removal the other day U must of had a premonition
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif "The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC " We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln |
07-03-2009 | #12 |
Throw out bearing came apart....
07-03-2009 | #13 |
Time to go Fidanza and Ceramic Baby !!!!
07-03-2009 | #14 |
Throw out bearing retaining ring?
07-03-2009 | #15 |
There were ball bearings inside the bell housing....retaining ring was fine
07-03-2009 | #16 |
07-03-2009 | #17 |
Yep! I knew it. It sounds like yours came apart worse than mine. Picture time.
Also Lee check to see if the clutch fork dug into the bell housing where the slave rod comes through. Because when the throwout bearing breaks and there's no resistance anymore the slave cylinder will binde the clutch fork against the wall and dig into it. A die grinder will smooth it out perfect. And WB9MCW is right about the Fidanza. If you can affort to dish out $325 on a Fidanza and a good clutch disk or a more high performance clutch then it only makes sense to do it while your at this point. I'm sure glad I did. Last edited by rhipsher; 07-03-2009 at 08:45 PM. |
07-03-2009 | #18 |
rhisper, Thanks for all the help...not so bad so far and if I had done it before it would be failrly simple. Having -=Jeff=-, Pete, and Dominic assist has also been a big plus..
Not looking forward to putting the C beams back. This job is much easier with the headers.....I bet cats get in the way.
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 07-03-2009 at 09:11 PM. |
07-03-2009 | #19 | |
07-05-2009 | #20 |
you are likely done already but the C beam plates make the job much easier and enhance the way the car drives by stiffening up the mounting points on the cbeam
I have a set ready to ship if you need em, $160 shipped out they really work well and make the job much easier. perfect time to put them in PM me or email at ron_kreigh@hotmail.com note there is an _ underscore between ron and kreigh
