Old 06-27-2009   #11
Kb7tif
Default Re: Lowering a '91 ZR1
Originally Posted by Aurora40 View Post
Springs don't work that way. The spring is pushing the car up with the same force as before, which is exactly the force required to counteract gravity. In order to provide that force, it will be as tensed as before. You are simply changing the mounting point, which changes the ride height.
If you are going to lower the rear of the car with longer screws, softening of the rear suspension will result, it did here and will do so there. So much so as i have looked at replacing rhe stock spring with a firmer spring. If I take out the lowering bolts I dont need the firmer spring. Something to consider..
1995 Convertible Supercharged Auto
1974 454 550hp (avatar car) On the blocks- -Scharger install !
1992-Zr-1 Sold.
Watson Headers
Ported Plenum, Housings
Random tech cats
Fidanza Flywheel
Chipped, Relocated Mat
Woods 165 stat
Borlas, Straights
1996 Lt4 Sold
1994 Lt1 Sold
2004 Z06 Sold
AKA** Illenema
Kb7tif is offline   Reply With Quote
