Old 06-17-2009   #11
Default Re: Silicone or rubber hoses
FWIW, I have made drawings for the PCV valve hoses, lower & upper, to obtain quotes for manufacture in Buna-N (stock) and Viton (black), in exact stock replacement configuration. I have sent it for quotation to the vendor who made the dipstick seals, but they declined to quote. I am preparing to send it out for quote to other prospective vendors.
Old 06-17-2009   #12
Pete
Pete's Avatar
I think the more choices more better for us, our ZR-1's and future buyers of the ZR-1's.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 06-17-2009   #13
Viton has a higher temp rating than Buna-N and has approximately the same chemical tolorance as Buna-N. I've seen several of the "F-hoses" that were rotton-soft on the engine side and still good (a little hard) on the firewall side. I think that it's due to heat. If I can get the hose in black Viton at a comperable cost, then that's what I will do. Making it identical in appearance to the OEM part is a top priority.
Old 06-17-2009   #14
Very possible in silicon, I might be able to put together an enitre kit for $140-$150...this would include all PCVs, Breathers, radiator, etc....
Old 06-17-2009   #15
limey
Lee,
I will give my input here.
If you have the interest to have re-manufactured, look into manufacturing and quoting these parts as neither myself or anyone we know of is doing these reman. These will be needed very shortly, esp since our NOS stock is almost exhausted.
  • Complete secondary vacuum hoses, full kits would be ideal, as like OEM in hard plastic and rubber where needed.
  • Air Horn intake bellows, made just like oem & not the samco style (After all, it's already available, unless you want reman by a different vendor to lower the cost)
  • Thermostat housing assembly
  • Coolant assembly crossover tube
  • Plenum connector pipes, these ae the aluminium tubes that attach to the plenum and always break off when removing
  • Power key switches
  • Power key bezels
  • etc etc etc.
There really is no need to manufacture the PCV Hose out of silicone, it's already been done, the PCV Baffle hoses in silicone are also done, We have these on our website now:
You can make the PCV Hose out of rubber if needed i guess, but it goes back to use our limited resources to manufacture items that haven't been manufactured, unless your intentions are to find lower prices.
Your cam cover emblems venture is excellent and once you get the emblem closer to stock apperance, you'll have a winner. In fact, i'll buy 50 sets from you once you get them sorted.
limey is offline   Reply With Quote
Old 06-17-2009   #16
limey
If you can compile this kit for $140.00 - $150.00, you can count me in for 50 sets of these too!
Old 06-17-2009   #17
I am not in it for big $, just looking to keep the LT-5s up and running for us common guys.
Old 06-17-2009   #18
billybaloneey
billybaloneey's Avatar
The SAMCO hoses serve a purpose in a pinch, but I just can't get past their large script/logo advertising plastered all over the hoses. They have the right, it's their product. I bought a set of black SAMCO hoses to add to my spare parts stock pile, but have been fortunate enough to not have to use any of them.
I would buy and use plain black hoses if they were available. Add me to the list of prospective buyers.
billybaloneey is offline   Reply With Quote
Old 06-17-2009   #19
Pete
Pete's Avatar
Yeap,keeping the prices down sounds like a good thing,also.
Heck $20 for dipstick seals coming on who are we kidding.
I found a non OE piece that costs .50 cents and available at local parts stores works just fine.
Secondaries we don't need no stinking secondaries.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 06-17-2009   #20
USAFPILOT
USAFPILOT's Avatar
I'd be in for a set of plain black...i want every replacement hose the LT5 could ever need. I have none and the car is getting old. Plus I want to do injectors soon and would like to just replace everything under there while I do it. Make it new again...kinda.
