Old 06-01-2009   #11
secondchance
Default Re: Gasoline of choice
Tear an engine apart that has been running on race gas, and then the same motor with regular pump gas, and the difference will astound you.
Could you elaborate? Race gas has no detergent and and creates more deposit? Or the reverse?
Old 06-01-2009   #12
Polo-1
Race Gas has lots of Toluene in it. Major Cleaner.
Old 06-01-2009   #13
evl_twn
evl_twn's Avatar
This worries me more than what brand:
http://www.businessweek.com/lifestyl...514_058678.htm
Has anyone had issues with the currently available ethanol blended fuels? Or is this nothing to be concerned about?
evl_twn is offline   Reply With Quote
Old 06-01-2009   #14
secondchance
I remember a former member of another forum (may be he was a member here too), Rat Racer. He use to prescribe occasional addition of toulene in gas tank.
Old 06-01-2009   #15
secondchance
Yes. You are right!
I just replaced all injectors and 10% ethanol is my primary suspect (and age of the car too to be fair...).
Old 06-01-2009   #16
RICHARD TILL
i run sonoco 110 octane leaded gas in a 10 second dragboat with brodix heads. valve seals on the intake but not the exhaust. for the last five years that i`ve done annual checks i`ve never found any deposits on any of the valves. the exhaust valves have a lite tan color and the intakes are a little darker. on the next spring change i`m taking the intake valve seals off. i`m also keeping in mind that this motor does`nt know but two levels of rpm`s, high idle for warm-up and wot. the ZR-1 does`nt drink anything but bp 93 octane and i hope i never lay eyes on those valves.
Old 06-02-2009   #17
two more cents from the peanut gallery. I use BP or shell, chevron when I can find it. I haven't looked in about 4.5 yrs, when I changed the injectors, man my 2* system was all kinds of gummed up.
After this weekends cruise I decided that unless I'm up around 80, sixth gear doesn't exist. I swear the car just seems to be smoother after an extended use at 2k rpms or higher.....the trip to BG & back was bliss for my car....for me where I live 4th & 5th seems to yield a great result in the existing traffic on my local highways and the car just seems to be smoother....it even sounds better
Old 06-02-2009   #18
rkreigh
well this is one place that I think techron and chevron gas might be Ok, but I use BP/Amoco and Sunoco
my "gas quality meter" is my turbo buick. I run full boost with the knock retard gauge on to watch for detonation. the 93 stuff works just fine even with the higher compression on the LSV
this is another time I'm glad I had marc yank the secondary flappers
my car runs on both injectors all the time except dead idle. one disadvantage is emissions. torq stayed the same with just a slight bump in midrange. but the secondaries stay cleaner!
Old 06-02-2009   #19
secondchance
Until about 4 years ago, Sunoco station in McLean had 94 octane as well as 93 but they stopped selling 94.
Nonetheless, with new reconditioned injectors, detonation is a thing of the past!
I think I will stay w/ 93 Exxon and/or BP/Amoco, splice in a oil catch can, and mash the throttle once in a while to get juices flowing into secondaries.
Old 06-02-2009   #20
Aurora40
Aurora40's Avatar
Couldn't the race gas difference also be attributed to the fact that if someone is using race gas, they are also probably driving their car hard quite often? You probably don't have someone cruising 500 miles to Bowling Green on race gas, for example.
