Old 05-28-2009   #11
Scrrem
Scrrem's Avatar
Default Re: Rear Window Replacement
Rich,
how bad is the plate you don't want to use? my hatch is also not attached perfect and I may attempt to remove it from the plate, but my plate is 'bowed' I might be interested in the one you don't use
The edge is scraped up pretty good from having the glass stored on that edge and it has a small dimple that looks like it was there before it was painted over at the factory. I'll try to take some pics
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 05-28-2009   #12
Scrrem
Scrrem's Avatar
Originally Posted by QB93Z View Post
Rich, If you decide to attempt the repair at home, give me a call and I will come help. I seems like a job where helpers holding the glass would be an advantage.
Jim, I may take you up on your offer. I have Kirk also lined up to help out, now just need to decide when to do the deed and I'll give you both a shout. Thanks much!!
Rich
Ron Davis Radiator
Old 05-28-2009   #13
secondchance
Rich
I am local too. Call me if needed - 703 980 8814.
Old 06-01-2009   #14
Scrrem
Scrrem's Avatar
That top piece is bonded to the glass, IMHO you are better of painting the new piece on the hatch to match
Well, got my wrench today and got the spanner nuts off and YEP the hinge plate is bonded to the glass and on to stay!!! Looks like I bought a piece of glass for nothing. It would be cheaper to try and remove the window tint than have the hinge plate re-painted
Rich
Ron Davis Radiator
Old 06-01-2009   #15
kirkstingray
Hi Rich you seem to have forgotten that I am a glass man by trade. You have everything you need right here in your own backyard just ask.
Kirk
kirkstingray is offline   Reply With Quote
Old 06-03-2009   #16
I talked to Gordon Killebrew years ago about removing the hinge plate to repaint it on a car I had and was told its next to impossible to get the adhesive to soften up to remove the plate.I would be interested in a spare hinge plate if somebody has one laying around.
